Why did my truck begin to crank on its own? - Page 2 - Ford Powerstroke Diesel Forum
 5Likes
post #11 of 17 Old 05-04-2018, 07:41 AM
"RLTW" Tennessee
F250_SUPER_4x4's Avatar
Quoted: 295 Post(s)
Contact your local pastor and make an appointment for an exorcism.
mhatlen likes this.
1974 F100 RC 351W/C4
1978 F250 Super Cab 400/C6
2015 F250 PSD CC KR 408/6R140
2017 Harley Ultra Limited 107/6SPD
F250_SUPER_4x4 is offline
post #12 of 17 Old 05-04-2018, 07:42 AM
sbluke55's Avatar
Quoted: 892 Post(s)
Garage
If you just replace the starter solenoid. You messed up and put some wires in the wrong spot. All power to the truck goes through it.
Heavy_GD likes this.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #13 of 17 Old 05-04-2018, 08:14 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 874 Post(s)
Feedback Score: 3 reviews
Inspect the main electrical system: alternator, grounds, primary wires, batteries..etc etc. Inspect the steering column and key cylinder.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #14 of 17 Old 05-04-2018, 08:35 PM
Quoted: 230 Post(s)
The starter circuit goes through the under dash fuse box / relay center to get to the GEM. So if it IS corroded or jankey, it could be the problem. We had another jankey fuse center on here earlier this week.
DaveP. is offline
post #15 of 17 Old 05-05-2018, 07:34 PM
Quoted: 17 Post(s)
That would be me! When the windshield leaks, it goes through a "funnel" created by the main fuse box grommet. This drips it directly onto the ventilation slots in the back of the GEM under which sits all the connector pins - so everything controlled by the GEM stands a chance of shorting to the pins around it. From the there, the water flows into the bottom left of the fuse box which acts as a cup to allow the water to rise about halfway up the fusebox. When I removed mine, it looked like it was recovered from the Titanic.
Replacement parts are about $100 each on Ebay. I managed to find a GEM manufactured on the exact same day as my fried one! Just search the part number shown on the side. Also, OEM replacement windshields are the same price as aftermarket (around me) so don't let them give you a crap one!
mhatlen and DaveP. like this.
2000 ECLB 4x4 7.3L PSD - Converted from a beat up XL farm truck and frame off restored thanks to New England road salt
Cosmetic: 05 Harley front end, 11 tailgate, black sport full power interior, 05 dash with aux switches and brake controller
Performance: AFE intake, SPX billet compressor wheel, Turbomaster wastegate, blank pedestal & exhaust housing, MBRP 5" exhaust, PHP Hydra, gauges and CTS2
Audio: Sony XAV-AX5000, JBL Club speakers, fully sound deadened
Lt.Dan is offline
post #16 of 17 Old 05-05-2018, 09:06 PM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1682 Post(s)
Garage
Originally Posted by PrinBaze View Post
Looks like the solenoid short circuited because its melty looking. Took it off to replace. Idont know why this would happen on its own. Now there's no power from the fuse box
Its a man made mechanical gizmo and things go to hell over time causing all kinds of disasters. Don't feel like Murphy only ever kicked you in the rear. Guy gets around with enuf for all of us.
Get it in order as well as you can and keep the truck out of the storms if water is going to be entering areas not friendly to water. Things will only get worse from here if you have water entering the electrical system. .
Not so sure I'm helping, but I'm staying busy so its a win...... well for me.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3 CAC Pipes & CSF 7106 I.C.
4 Diamond Eye SS Exh System
W/two 4 SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #17 of 17 Old 05-05-2018, 09:12 PM
mhatlen's Avatar
Garage
LMAO just saw you thoughts here. lol I am not far off your thinking there. I am doing what I can though its very low on value.
CAT EC-1 coolant
mhatlen is offline
