No Boost Until High RPM - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-28-2018, 07:03 AM Thread Starter
Quoted: 19 Post(s)
Like the title says, I'm building 0psi until maybe 2500rpm, then only a couple psi. If I lug it in 4th, it will build 25psi or so before I let off the throttle. I just rebuilt the turbo with a billet wheel, bearings, etc and it's sitting on a deleted pedestal with all new o rings. I have a turbomaster wastegate on there which hasn't been adjusted since I can't get a good reading. I can hear the turbo spooling at all rpms, however it is much quieter than I thought it should be considering the intake, 5" exhaust, removed foil, and billet wheel.
Any ideas?
2000 ECLB 4x4 7.3L PSD - Converted from a beat up XL farm truck and frame off restored thanks to New England road salt
Cosmetic: 05 Harley front end, 11 tailgate, black sport full power interior, 05 dash with aux switches and brake controller
Performance: AFE intake, SPX billet compressor wheel, Turbomaster wastegate, blank pedestal & exhaust housing, MBRP 5" exhaust, PHP Hydra, gauges and CTS2
Audio: Sony XAV-AX5000, JBL Club speakers, fully sound deadened
Lt.Dan is offline
post #2 of 3 Old 04-28-2018, 07:13 AM
DieselDC's Avatar
Quoted: 682 Post(s)
Well your wheel isnít slipping since youíre building boost in 4th. Whatís your hot side size? .84, 1.0 etc?
You gotta adjust that wastegate.
Other thing I can only think of is a boost leak
ďDonít overthink something simple people... ..:sigh:..Ē
DieselDC is offline
post #3 of 3 Old 04-28-2018, 09:45 AM Thread Starter
Quoted: 19 Post(s)
It's stock off a van turbo, which I believe is .84.
The wastegate is set at the manufacturer recommended "safe" setting for those without boost gauges. I should have mentioned I'm heading boost through the MAP sensor (CTS2) and through a mechanical boost gauge tapped into the MAP line before an overboost regulator.
A boost leak was my first thought because I didn't see it ever building boost, but it's curious that it holds that 25lbs under certain conditions. I'm kinda thinking I left a rag in one of the intercooler passages.
Currently, the truck is dead in a parking lot somewhere so I want to investigate when I get it home. Just seeing if others had something I was overlooking. Thanks!
Lt.Dan is offline
