HELP! Truck is Haunted (Parasitic Drain) - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 16 Old 04-28-2018, 08:32 PM
GETFURIOUS's Avatar
Quoted: 245 Post(s)
Originally Posted by DieselDC View Post
I don’t know why hour trucks are so prone to windshield leaks.... I’ve have four 7.3 and each had leaked at the driver side. Kinda tire of the bs. None of my Toyota’s have leaked at all. Diesel power hungry problems.
“Don’t overthink something simple people... ..:sigh:..”
I BELIEVE THAT ONCE THE "ORIGINAL" WINDSHIELD HAS BEEN REMOVED.....ANY REPLACEMENTS WILL ONLY HAVE ISSUES IF THE INSTALLER DID NOT DO THE JOB RIGHT.....OR IT WAS INSTALLED OVER RUST.....
2001 F-350 4X4 ECLB SRW.....CURRENTLY IN THE SHOP FOR SOME MAINTENANCE.....SHOULD BE ON THE ROAD SOON?....
CURRENTLY LOOKING FOR AN AFTERMARKET REAR BUMPER.....
GETFURIOUS is offline
post #12 of 16 Old 04-28-2018, 08:34 PM
DieselDC's Avatar
Quoted: 682 Post(s)
It should not leak period. I can’t count one time I had a leak on the dozens of Toyota’s we’ve had.
DieselDC is offline
post #13 of 16 Old 04-28-2018, 09:21 PM
GETFURIOUS's Avatar
Quoted: 245 Post(s)
YOU ARE CORRECT.....THE WINDSHIELD SHOULD NOT LEAK.....BUT.....
IF THE TECH DOES NOT SEAL IT PROPERLY WHEN INSTALLING IT.....IT WILL LEAK.....
IF THE TECH INSTALLS AND SEALS OVER A RUST SPOT.....IT WILL LEAK IN MOST CASES.....
I HAVE SEEN THIS IN MANY BRANDS.....INCLUDING TOYOTA.....HONDA.....FORD.....GM.....
post #14 of 16 Old 04-28-2018, 09:36 PM
DieselDC's Avatar
Quoted: 682 Post(s)
From the factory - there is no rust. With my experience, since good luck has been in my favor from Toyota’s, I’m Venture to say techs from Toyota are far more qualified when it comes to windshield
DieselDC is offline
post #15 of 16 Old 04-28-2018, 09:40 PM
GETFURIOUS's Avatar
Quoted: 245 Post(s)
I WASN'T TALKING ABOUT THE ORIGINAL FACTORY WINDSHIELDS LEAKING.....I WAS TALKING ABOUT ONCE A WINDSHIELD HAS BEEN REPLACED.....
post #16 of 16 Old 04-28-2018, 09:42 PM
DieselDC's Avatar
Quoted: 682 Post(s)
I was talking about oem... all my SD have replacement windshields.... this is the #1 cause of electrical issues in our trucks. Ford should have left the fuse box under the hood.
DieselDC is offline
