alternate location for oil bypass filters? - Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By DaveP.
  • 2 Post By bluemaruder001
post #1 of 7 Old 04-15-2018, 06:15 AM Thread Starter
Quoted: 8 Post(s)
I ordered an dual filter oil bypass setup from Amsoil, and it seems to be that it's intended to mount behind the front wheel on the outside of the frame, kind of below the door hinge area.
I don't like that location, the filter seem vulnerable there. I don't do a whole lot of offroading in the truck (that's what the jeeps are for!!) but I do take it on mild trails every now and then.
Is there a limit to how far away you can mount the filters? Seems like somewhere under the bed of the truck towards the rear, might be a safer, roomier location, would running the oil lines that far be a problem, assuming they are tucked up and out of the way? Oil pressure sufficient to run that far?
2000 f250 Superduty, 7.3, 4x4, regular cab, long bed, 6 speed manual, 315/70/17 Dick Cepek tires.
error404 is offline
post #2 of 7 Old 04-15-2018, 07:08 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 33 Post(s)
I'd opt to keep it closer because of oil pressure but I don't think you'd have too much of a problem since the filter samples the flow.
My personal concerns with running lines to the rear would be the (what can go wrong, will go wrong) risk of any debris potentially damaging the lines unless you bullet proof everything (in the frame rail, some kind of wire loom/durable cover).
Have you considered running it horizontally?
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 7 Old 04-15-2018, 07:47 AM
ZMANN's Avatar
Quoted: 3956 Post(s)
I would just make a shield for the Amsoil
6.0 flush pdf
ZMANN is offline
post #4 of 7 Old 04-15-2018, 06:05 PM
Quoted: 230 Post(s)
I would just leave it in the box on a shelf in the garage. Don't put it on the truck at all. Nothing can go wrong if it isn't installed.
GETFURIOUS likes this.
DaveP. is offline
post #5 of 7 Old 04-16-2018, 08:13 AM Thread Starter
Quoted: 8 Post(s)
The unit I have has both filter (main filter, and bypass filter) in one bracket, so flipping it sideways wouldn't really gain much.
I wouldn't feel bad about running the lines all the way to the back, I think getting them inside the C frame wouldn't be difficult.
error404 is offline
post #6 of 7 Old 04-16-2018, 08:15 AM Thread Starter
Quoted: 8 Post(s)
I thought about that, but seems like it would be simpler just to move it elsewhere that doesn't require a shield.
Noted. I'd really like to extend the time in between oil changes though. I drive roughly 100 miles a day, and 14 quarts of oil every month or two adds up.
error404 is offline
post #7 of 7 Old 04-19-2018, 03:10 PM
bluemaruder001's Avatar
Quoted: 9 Post(s)
Take a look at my pics, I had a bracket fabricated and it worked great!, let me see if I can add it here, if not is on my page It was measured to fit inside the frame rails basically boxing the section. Bolted from the bottom. I had it made to where it was a bit wedged in, been installed over 10 years and no problems.
ID:	693601   Click image for larger version
ID:	693609   Click image for larger version
ToyMan and Got Dirt? like this.
2016 CCSB 4X4
6.7 Powerstroke (completely stock) for now.
2001 CCSB 4X4
All Amsoil Fluids
Hutch, Harpoon Mods
Ford AIS intake
Amsoil Bypass Oil filter system
6.0 Trans Cooler
Diesel Site External Trans filter
Diesel Site Coolant filter
Racor fuel filter
Riffraf FRx HPx
Riffraf Plenum inserts
Riffraf check valve delete
Diesel Site CAC boots
International bellowed up pipes
Banks Big Head wastegate and Banks compressor wheel
Banks 4in Turbo back exhaust
Banks Turbo boost, trans temp, pre turbo and post turbo EGT on pillar.
Autometer water temp and HPOP pressure overhead
bluemaruder001 is offline
