Ford Powerstroke Diesel Forum
Ford Powerstroke Diesel Forum (https://www.powerstroke.org/forum/)
-   99-03 7.3L General Discussion (https://www.powerstroke.org/forum/99-03-7-3l-general-discussion/)
-   -   7.3 gallons per hour at idle ? (https://www.powerstroke.org/forum/99-03-7-3l-general-discussion/133073-7-3-gallons-per-hour-idle.html)
crazy_canadian 01-28-2010 08:48 PM
Does anyone know how much fuel does a 7.3 use in an hour ? At idle, no a/c.
And also, I heard that the 6.0s dosen't really like long idle period because of the turbo. Does the 7.3s care about doing a hour or more of idling ?
Thanks!
Tyler 01-28-2010 08:51 PM
Burns a half gallon and hour... you can let them both idle as long as you want, just be sure to "clean" it out :evillol:
choctaw 01-28-2010 08:56 PM
It's not so much the turbo on the 6.0's as it is the EGR valve.
berto4599 01-28-2010 10:16 PM
its not very good to let any diesel engine idle for long periods of time. It will glaze the cylinder walls causing lots of blowby and low compression.
choctaw 01-29-2010 04:35 AM
Could you elaborate, please.............................
Dave 01-29-2010 04:58 AM
:doh::doh:
Nope. Wet stacking could be a concern though. But if its idled up a little you're good.
As to the 6.0 the new flash fixes the sticky vanes at idle issue.
bucwheat 01-29-2010 05:55 AM
I usualy idle mine up before idleing a half hour or longer.
Fordman247365 01-29-2010 07:49 AM
sitting at a dead idle isnt bad as long as it isnt for a long period of time. If it is going to be run for a long period you should find some way to raise the idle at least a few hundred rpm, 1000 rpm would be probably the best. Go where its cold, sometimes trucks hardly ever get turned off in the winter. I myself have run them around the clock, but to run them all the time the idle needs to be raised
TurboTPI 01-29-2010 08:10 AM
How would extended idling cause cylinder wall glazing more than running it at higher rpms? I've let my truck idle for hours on end. I have 165,000 miles with no more blowby then when it had 100,000 miles. And still has the same power. Newer electronically controlled diesels don't wash down cylinders like the old mechanical diesels do. If that what your thinking.
Tyler 01-29-2010 08:20 AM
:hehe::hehe::hehe::tard::tard::tard:
Dude oh my god:hehe::hehe:
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
