Torque Pro & Car Guage Pro questions - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By guitarnut
post #1 of 9 Old 01-21-2018, 09:42 AM Thread Starter
oilcan1001's Avatar
Quoted: 139 Post(s)
Question Torque Pro & Car Guage Pro questions
So I very recently acquired these 2 apps along with an OBDLink LX and am trying to get familiar with these tools so when I need them I have some knowledge. ( notice I say some, lol)
1st pic- is CGP after a complete scan it gives me this message and not sure why
2nd pic- was CGP before clearing all codes
3rd pic- is CGP after clearing all codes and driving about 50 miles
4th pic- is a Torque Pro scan.... no codes ?
Why do I get codes on one app and not the other ?
Should I be concerned about the codes I am getting ?
Thanks in advance
Name:	after complete scan.JPG
ID:	673442   Click image for larger version
Name:	B4 clearing.JPG
ID:	673450   Click image for larger version
Name:	after clearing.JPG
ID:	673458   Click image for larger version
2001 F-350 7.3 Powerstroke
Lariat, 4x4, CC, SRW, LB, AT
AIS intake
3/9/17 - bought used 194k miles
3/15/17- New stock radiator
3/15/17- New 6.0 OEM 26 row trans cooler
4/15/17- Edge Insight ( with EGT)
6/9/17 - Hydra with stock PHP tunes
2004 32' Sandpiper 5th wheel by Forest River - 11,000# fully loaded
Andersen Ultimate 5th Wheel Hitch
oilcan1001 is offline
post #2 of 9 Old 01-21-2018, 04:37 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 36 Post(s)
Compare your stats and results with numbers in this thread: https://www.powerstroke.org/forum/gen...pp-photos.html
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
The Following User Says Thank You to AgTires4295 For This Useful Post:
oilcan1001 (01-21-2018)
post #3 of 9 Old 01-21-2018, 09:15 PM Thread Starter
oilcan1001's Avatar
Quoted: 139 Post(s)
Thanks for the link AgTires.
I've read through 52 pages so far and think I'll be needing stronger glasses now, lol.
I know you have a lot invested in that thread so can you tell me if anyone had luck pulling codes with torque ?
That was a big reason for my original question.
AIS intake
post #4 of 9 Old 01-22-2018, 06:20 PM
Quoted: 113 Post(s)
CGP wants the MX version of the adapter which is more $.
If you have a chip installed oftentimes codes aren't accurate.
Sent from my SM-N920G using Tapatalk
guitarnut is offline
post #5 of 9 Old 01-23-2018, 06:26 AM Thread Starter
oilcan1001's Avatar
Quoted: 139 Post(s)
I thought OBDLink 'MX' version was for vehicles '03 and up.
Am I wrong ?
I do have a Hydra running canned PHP tunes.
So my codes are not accurate ?
I need more input ......
Thanks
AIS intake
post #6 of 9 Old 01-23-2018, 07:07 PM
Quoted: 36 Post(s)
an you tell me if anyone had luck pulling codes with torque ?.
Glad you made it through all of that LOL
I've used the codes pulled and have come up with diagnoses that I'm able to use. It's been over the past few years so I can't remember what specifically but the most recent was the OD light flashing. Torque was able to specify the code, decipher it and tell me that I had a bad connection from the column shift to the trans electrical input.
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #7 of 9 Old 01-24-2018, 09:01 PM
Bri_Man57's Avatar
Quoted: 167 Post(s)
I do feel like when I pulled codes with Torque, it did a few weird things. A couple times it disconnected right at the end of the code reading, 1 time I heard a bunch of relays click, CEL comes one, have a ton of codes with no start. Key off, then back on and back to normal. I read where peopels truck would turn off when reading codes and would restart until the key was cycled. I feel like that was the problem I had, just the motor was already off.
I did get it to work a few times though. Not sure what is going on there.
Bri_Man57 is offline
post #8 of 9 Old 01-25-2018, 01:27 AM
Quoted: 113 Post(s)
Imho torque is better for monitoring and CGP is better for diagnostics.
oilcan1001 likes this.
post #9 of 9 Old 01-25-2018, 05:46 AM Thread Starter
oilcan1001's Avatar
Quoted: 139 Post(s)
This is what I'm leaning towards, but spending more time with these will give me my final conclusion.
AIS intake
