Preferred Serpentine belt?? - Page 2 - Ford Powerstroke Diesel Forum
 6Likes
post #11 of 40 Old 12-28-2017, 06:02 PM Thread Starter
Vohs's Avatar
Quoted: 123 Post(s)
Garage
Originally Posted by early99psd View Post
Was the belt changed at the same time as the tensioner and idler? I would check all of the pulleys for wear. It looks like something is definitely chewing it up. I had a belt once that i put on that was off one rib on a pulley and it chewed one side off.
As far as I know the guy told me he had the belt changed at the same time, I have the old idler and tensioner in the box behind the seat.
had the belt off today, cleaned all the pulleys and took a brush to the groves. Cleaned all the belt dressing off.
to conquer without risk is to triumph without glory.
Vohs is offline
post #12 of 40 Old 12-28-2017, 06:03 PM
DieselDC's Avatar
Quoted: 682 Post(s)
Keep the extra belt in the glove compartment.
Sent from my iPhone using Tapatalk
Vohs likes this.
DieselDC is offline
post #13 of 40 Old 12-28-2017, 06:04 PM
early99psd's Avatar
Quoted: 36 Post(s)
Hows the water pump?
KC38R, CNC Fab stage 1 HPOP, PHP Hydra, (1023, Gearhead & PHP tunes), AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
post #14 of 40 Old 12-28-2017, 06:10 PM Thread Starter
Vohs's Avatar
Quoted: 123 Post(s)
Garage
New pump, new alternator and new power steering pump lol.
Vohs is offline
post #15 of 40 Old 12-28-2017, 06:18 PM
early99psd's Avatar
Quoted: 36 Post(s)
The only other thing I can think of, is on mine the driver side intercooler pipe is close to the power steering pulley. Check the clearance there. If it all looks good I would throw a new belt on and see how it goes.
post #16 of 40 Old 12-28-2017, 06:21 PM Thread Starter
Vohs's Avatar
Quoted: 123 Post(s)
Garage
Yea thatís the route Iím going to take, canít handle pulling up to a light and squeaking like crazy at least I think my rig looks like it shouldnít squeak haha.
Vohs is offline
post #17 of 40 Old 12-29-2017, 02:34 PM
Quoted: 230 Post(s)
Squeaks are caused by misalignment between two pulleys. The pulley "leading" the shortest span is usually the one out of alignment, causing the squeak.
Vohs likes this.
DaveP. is offline
post #18 of 40 Old 12-29-2017, 03:21 PM Thread Starter
Vohs's Avatar
Quoted: 123 Post(s)
Garage
Anyone know the correct belt size for a early 99 single alternator with (cold weather package)? The belt I have on the rig, the one they said they replaced specs at 122.91 pretty sure thatís the wrong size and itís slipping.
Vohs is offline
post #19 of 40 Old 12-29-2017, 03:49 PM
Fire From the Clouds!
Horizon122's Avatar
Quoted: 233 Post(s)
I went with the dayco green heavy duty belt. You can find it around $40 on Amazon. I also replaced all my pulleys with OEM, no issues 30K miles later.
Vohs likes this.
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 PMF lift on 325/60r20 Nitto M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
post #20 of 40 Old 12-29-2017, 04:06 PM
DieselDC's Avatar
Quoted: 682 Post(s)
Wanting to replace my pulleys too but at a later time? Could you possibly provide the part# for which is which? Thx
DieselDC is offline
