Injectors - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-12-2017, 04:38 PM Thread Starter
Injectors
Has anyone had to replace all 8 injectors at one time on 2000 F450 with 7.3.
Power is way off. Thoughts.
None of them have ever been replaced. Miles 221,550
clayhill is offline
post #2 of 10 Old 12-12-2017, 04:57 PM
DieselDC's Avatar
Quoted: 682 Post(s)
Replace the ones you need - do a buzz test. If it were me, 200k is pretty much tired for anything and sensors on the motor - I would replace them all.
edit: I would do some soul searching about now and see if the beast is worth it(yes its worth it) for some 160/30 sticks. There's a set on here for sale that I saw the seller wants $1600+ for stock sticks and I kinda chuckled inside. New set of 160/30 @cncfab is around that much. Tuner is another $300 (i think he's having a special for $275)
Sent from my iPhone using Tapatalk
DieselDC is offline
post #3 of 10 Old 12-12-2017, 04:59 PM
cletusjermal's Avatar
Quoted: 406 Post(s)
Have you done any test to make sure they are all bad?
2017 F350 6.7L 4x4 FX4 SRW CCSB Lariat Ultimate
Sold—2002 F350 7.3 4x4 SRW CCLB. GTP38R, PIS 175/80 injectors, Sam Wyse Stage 2 Trans, 6.0 cooler, Banks Intercooler, 4" Turbo back Exhaust, PHP tuned TS 6 position chip, CNC 4 Line feed, HPOP and HPX Lines. International bellowed up pipes. AFE Stage 2 Intake w/ Dry filter. Banks exhaust brake and smart lock. Hutch/Harpoon mod, 910 Valve springs, Billet intake plenums. Firestone airbags. Trailready full guard front bumper. PIAA Driving and Fog lights. Micky Thompson Wheels.
cletusjermal is offline
post #4 of 10 Old 12-13-2017, 05:31 AM
blue99stroker's Avatar
Quoted: 393 Post(s)
Garage
While they are may be getting tired at 200k they should have some miles left.
Usually a 200k truck has boost or exhaust leaks.
And a few bad sensors. especially Icp
99.5 f250 7.3 4x4 279k FF 160/30, Hydra w/SDK Tunes, S&B, 4" Exhaust, Van Turbo w/Riffraff Billet Wheel, Autometer Gauges, Built trans, 08 Tow Mirrors, Trucool Max.
Dad- 2000 F250 7.3 4x4 124k Autometer Gauges, Superchips 1705 (Tow Safe), K&N Intake w/Amsoil Filter, 4" Exhaust, BD Billet Wheel, Trucool Max, Modified VB, 08 Tow Mirrors.
blue99stroker is offline
post #5 of 10 Old 12-13-2017, 12:30 PM
greenskeeper's Avatar
Quoted: 300 Post(s)
or poor fuel pressure (regulator or in-tank screens)
closing in on 250k on my 99 with original injectors
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD 203K all original
99 F-250 CC 4x4 7.3L PSD ZF6 253K all original
greenskeeper is offline
post #6 of 10 Old 12-13-2017, 01:06 PM
DieselDC's Avatar
Quoted: 682 Post(s)
I had 200 in mine and the other had 400 lol. I still say 200 is worn to chit but hey, I rolled the dice and the OP is welcomed to do the same.
The way I look at it is if one starts to take a dip south - it must be either bad or something made it bad (poor oil/debris/crap ⛽️) , I won’t chance it so I upgraded to 160/30. Eventually more will go bad and it’s a pain to change injectors if you’re changing one at a time. If they were all good - roll with it till one or three goes bad.
DieselDC is offline
post #7 of 10 Old 12-16-2017, 12:24 PM
Quoted: 19 Post(s)
240k on my stock injectors and still doing the job.
2000 Ford Excursion 7.3, 3.73 Bone stock 249k
2014 Ram 2500 megacab 6.7 Cummins, 3.42s 68RFE, Tuned and deleted by Hardway Performance. 85k
smeash is offline
post #8 of 10 Old 12-23-2017, 10:03 PM
SC-Surfer's Avatar
Quoted: 139 Post(s)
Garage
New to these trucks. Can someone point me in the direction of an article or info on what the injector numbers mean?? I.e. 160/30? Etc.
Sent from my iPhone using Tapatalk Pro
2002 F350, 7.3l, CCLB, WW2, HPOP crossover, Coolant bypass filter, ATF inline filter, 4" exhaust, afe intake with AIS, 4" lift, 35's, Hellwig Big Wig F/R, Rancho900XLs, Firestone bags, PHP Hydra.
SC-Surfer is offline
post #9 of 10 Old 12-24-2017, 07:29 AM
Quoted: 406 Post(s)
160 is the amount of fuel. 160 cc’s of fuel per 1000 injections. The 30 is the % over the stock nozzle. So 30% larger holes vs the stock hole size in the injector tip. The stock size is 140/0 if I remember correct.
Here is a thread to help pick injectors and what you can do with the different sizes.
https://www.powerstroke.org/forum/99-...-upgrades.html
Edit. Stock is 135. Also stock is a split shot injector which means it does an initial shot and then the main shot per injection cycle. Most aftermarket ones are single shot which just does one shot per cycle.
The Following User Says Thank You to cletusjermal For This Useful Post:
SC-Surfer (12-25-2017)
post #10 of 10 Old 12-25-2017, 11:31 AM
SC-Surfer's Avatar
Quoted: 139 Post(s)
Garage
Thanks cletusjermal. Will read up!!
Merry Christmas All!
