Oil pan drain valve question - Page 2 - Ford Powerstroke Diesel Forum
 6Likes
post #11 of 28 Old 11-13-2017, 11:15 AM Thread Starter
KBS
KBS's Avatar
Quoted: 10 Post(s)
Originally Posted by zsargent View Post
While it's draining, replace your oil filter, check other things and VOILA! You be done.
Regarding the filter, it looks like a mess to remove, as most filters are. I saw one guy puncture the filter to let the oil drain out, thus preventing the nastiness when unscrewing the filter. That looks like a good idea. Anyone try that?
KBS is offline
post #12 of 28 Old 11-13-2017, 12:00 PM
DieselDC
DieselDC's Avatar
Quoted: 682 Post(s)
I do that each oil change. Just have a sharp pick at hand and whatever you do, donít hammer your finger lol.
Sent from my iPhone using Tapatalk
DieselDC is offline
post #13 of 28 Old 11-13-2017, 01:09 PM Thread Starter
KBS
KBS's Avatar
Quoted: 10 Post(s)
the Fumoto F111 on the ebays says it fits a 2001 F350 but not the F250. Really? Is there a difference in the oil pan on the two models?
Just answered my own question. The Fumoto website says F111 is the right one for the 2001 F250.
I'm kind of a cheap chiseler, and $26 for a convenient valve is kind of pricey, but I'm also very averse to making monumental messes and having used motor oil running down to my armpit, so maybe clean-freak trumps tight wad.
KBS is offline
post #14 of 28 Old 11-13-2017, 02:54 PM
JustinOOO9's Avatar
Quoted: 1517 Post(s)
Garage
Feedback Score: 3 reviews
Hey, no judgment here. What a dude does with his nipple is his own business, I always say.
But, back to the topic, the Fumoto F111 on the ebays says it fits a 2001 F350 but not the F250. Really? Is there a difference in the oil pan on the two models?
I just looked at my fumoto invoice and Im running the F111N on my 1999 f250 7.3l 4x4 auto. there is no difference in oil pans from 1999-2003 4x4 7.3l im not sure about 2wd though etc.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
Justin
JustinOOO9 is offline
post #15 of 28 Old 11-13-2017, 03:55 PM Thread Starter
KBS
KBS's Avatar
Quoted: 10 Post(s)
Thanks. I ordered one from the Amazons today. I'm 1,000 miles from the next oil change, but now I'll have it on hand when the time comes.
KBS is offline
post #16 of 28 Old 11-16-2017, 06:10 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 33 Post(s)
However much it was (~$20 when I bought mine some years ago), it's an added peace of mind to know that you'll never cross-thread or potentially strip out your oil pan threads with each oil change. Convenient, clean, effective. Set it, forget it, move on with more important things than dribbled oil.
DieselDC and GETFURIOUS like this.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #17 of 28 Old 11-16-2017, 06:16 PM
DieselDC
DieselDC's Avatar
Quoted: 682 Post(s)
If you can cross thread your oil pan bolt smh I donít know else to say (not saying you but in general).
I didnít cross thread mine - a tree or some chit hit mine (I didnít run into it Haha). It cost 1500 for a new oil pan so I guess I can say I fall in the same boat as those dumb*** that can cross thread the oil pAn haha. Itís funny thinking about it and like a true dumb***, I have another on on my truck after the bill haha.
DieselDC is offline
post #18 of 28 Old 11-16-2017, 06:42 PM
Brrrrrrr......cccccold
Quoted: 385 Post(s)
ex zach ly
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
zsargent is offline
post #19 of 28 Old 06-20-2018, 08:13 AM Thread Starter
KBS
KBS's Avatar
Quoted: 10 Post(s)
Well, folks, here's an update. This valve is a piece of $#!+. I woke up to an oil slick in my driveway this morning. The spring valve began to leak, and the only thing that kept it from draining my oil pan was the silly little plastic cap that I decided to leave on the drain valve. As it was, oil was dripping out, and when I removed the cap, it flowed out. I quickly replaced the cap and found my OEM plug. I removed the drain valve, plugged the pan with my finger, and put the OEM plug back in. I lost about a quart of oil, much of it down my arm.
Fortunately, this occurred in my driveway. I had just returned from a 1,000 mile trip in the southern Utah desert. If it had started leaking out there, I would not have known it, and my engine would have been destroyed. For whatever convenience you think you might gain from the drain valve, don't do it. It's a disaster waiting to happen.
KBS is offline
post #20 of 28 Old 06-20-2018, 09:08 AM
Quoted: 385 Post(s)
KBS
Are you sure you didn't leave it open by accident? As in touch the lever after you put the cap on? That's the FIRST time I hear of a failure on those. Mine's been on two trucks (transferred it), subjected to dozen of thousands of miles in all kinds of harsh weather (all the way down to -44F), hunting, fishing, towing, you name it.
Not one drop of oil has leaked out. Not one.
I think your experience is an anomaly, not the norm for sure.
Zach
168,084 miles....
zsargent is offline
