Oil leak (pics) - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By NoRalPh
post #1 of 10 Old 08-14-2017, 02:51 PM Thread Starter
Quoted: 5 Post(s)
Oil leak (pics)
I'm experiencing oil leaking. Not sure how bad it is. Can you see what my next steps are?
ID:	641418   Click image for larger version
ibuildme is offline
post #2 of 10 Old 08-14-2017, 05:04 PM
Quoted: 461 Post(s)
Feedback Score: 3 reviews
You're looking at the bottom,,,, but more often the leak is "Up Top".
There is a hole at the back of the valley where oil drains down, behind the flexplate against the back of the block, and drips out the inspection cover. What you want to do now is to use a flashlight and look under the spider into the valley for pools of oil.
Here's an interesting video, BUT I have to warn you about this guy,,,, he makes some Good Videos, that Does NOT make him infallible. He's got some really GOOFY theories (not about this though) So, don't take him as your Guru, as many do Confirm his advice on anything else he says
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
Also,,, what's with that swaybar link????
JustinOOO9 likes this.
NoRalPh is offline
post #3 of 10 Old 08-14-2017, 06:33 PM
hansel's Avatar
Quoted: 376 Post(s)
As stated above the oil is probably coming from the valley on top of the motor, climb up top and look down behind the fuel bowl and see if you find any oil puddling. Mine was loose clamps on the intake and that was a simple fix
2001 7.3L CCSRW 4X4
2003 7.3L CCDRW
S&B intake, 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission. Edge SCT2
PHP Hydra chip's
2015 Heartland Prowler
hansel is offline
post #4 of 10 Old 08-14-2017, 06:44 PM
Corey@CNCFAB's Avatar
Quoted: 1427 Post(s)
Feedback Score: 4 reviews
If there is no oil up top leaking down, the most other prone spot is the corner of the oil pan directly above the starter.
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
post #5 of 10 Old 08-14-2017, 09:22 PM Thread Starter
Quoted: 5 Post(s)
Thanks guys. I need a new one or can I just get the rubber piece? Idk
ibuildme is offline
post #6 of 10 Old 08-15-2017, 08:48 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 33 Post(s)
Originally Posted by ibuildme View Post
Thanks guys. I need a new one or just get the rubber piece? Idk
I'm confused by this question. What rubber piece are you referring to?
I sincerely think youre leaking from up top. Have you spent any time under the hood looking for the source yet?
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #7 of 10 Old 08-15-2017, 09:14 AM
JustinOOO9's Avatar
Quoted: 1633 Post(s)
Garage
If you look at the picture closely, a sway bar end link popped off the rubber bushing.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #8 of 10 Old 08-15-2017, 12:04 PM Thread Starter
Quoted: 5 Post(s)
It is leaking from up top. I don't know where exactly yet. Are there any main points you think it could be leaking from up top?
ibuildme is offline
post #9 of 10 Old 08-15-2017, 12:11 PM
Montstroke's Avatar
Quoted: 5 Post(s)
Turbo orings, intake piping (though doubt that much oil), HPOP fittings or HPOP itself for starters. Clean the valley really well and see where the oil is coming from, front to rear. I have had good luck laying a couple heavy duty shop paper towels down in there for a short time to tell better. A good mirror and a f'n bright light are your best friends now.
2001 F250 CCSB
P.I.S. 160/30 single shots
RR Donaldson Blue Filter
KC38R w/.84
EBPV gone
AIH gone
Turbo back 4" MBRP muffled
Hydra w/ PHP tunes
315's with Zone level kit
On board air
Suspension air bags
Montstroke is offline
post #10 of 10 Old 08-15-2017, 01:26 PM Thread Starter
Quoted: 5 Post(s)
Thanks Hombre
ibuildme is offline
