2005-2007 headlight conversion - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 03-28-2017, 06:14 AM Thread Starter
toad's Avatar
Quoted: 27 Post(s)
So my truck is at the body shop getting a fresh coat of paint. I was side swiped this winter so the insurance is paying for most of the bill. I figured I might as well paint the entire truck. So I am getting a grill for the 05-07 trucks. My headlights already have some moisture issues so I figure I might as well change them out also. I see some guys are cutting the header panel and using oem lights. I realize oem lights are better than aftermarket but kind of pricey. Is there a GOOD conversion headlight available. I dont care for the funky black lights. I want OEM style.
1996 F250 crew cab. Hypermax intercooler, Gearhead tunes, 4" exhaust, 6637 intake, Autometer gauges, Dana 60, 6.0 cooling fan, Built e40d, Firestone airbags, Full Force stage ones more to come. SOLD
2003 7.3 F250 Lariat. Mostly stock.
toad is offline
post #2 of 11 Old 03-28-2017, 06:25 AM
Heavy_GD's Avatar
Quoted: 3145 Post(s)
Garage
Feedback Score: 4 reviews
have you met @1ATony ?
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is online now
post #3 of 11 Old 03-28-2017, 06:42 AM
1AAuto.com's Avatar
Quoted: 72 Post(s)
We carry this grill and headlight kit. We also carry them separate.
2005 Ford F250 Super Duty Truck Chrome & Gray Grille & Headlights Kit
Hope this helps you out
Tony
Heavy_GD likes this.
Save on headlights when you buy in pairs + fast & free shipping!
1AAuto.com is offline
post #4 of 11 Old 03-28-2017, 06:59 AM
Heavy_GD's Avatar
Garage
This is one of the best how to's I could find.
https://www.powerstroke.org/forum/6-0...e-cutting.html
GD
post #5 of 11 Old 03-28-2017, 06:38 PM Thread Starter
toad's Avatar
Quoted: 27 Post(s)
For some reason I thought someone made a conversion headlight assembly that was just a bolt in. Am i wrong?
toad is offline
post #6 of 11 Old 03-28-2017, 06:41 PM
RollinEarly99's Avatar
Quoted: 9 Post(s)
Feedback Score: 10 reviews
Yes they do, did you check the link above from Tony?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #7 of 11 Old 03-28-2017, 09:26 PM Thread Starter
toad's Avatar
Quoted: 27 Post(s)
Unless I am missing something those lights listed are stock replacements for 05-07 ford. Require cutting of the front header panel?
toad is offline
post #8 of 11 Old 03-29-2017, 07:37 AM
Quoted: 25 Post(s)
The 05-07 headlights that are OEM style require a different header panel - that's about as bolt on as you get. Remove the old lights and header, bolt on the new header, harness adapter, and lights.
Else, cut your header. Took me about 20 minutes/side to cut. Very easy to do. The lights from Tony are tops and are much better than stock.
The lights you get will require a harness adapter too... the 05-07 harness was different than ours.
Overall - I did my lights in about 3 hours - including numerous breaks to stand back and admire my great work.
01 F350 Dually 4x2 Long 7.3 - Manual - Mods: Hutch, Harpoon, Remote Fuel Filter, Dual Disk Southbend Clutch, Heim Joint, Gauges, Disabler, 08 Tail w/Camera, Pioneer Head w/Lockpick, Exhaust Brake, Rails, Air Raid, 06 Headlights, 50 cent, Air Bags, Hydra, Riff Raff Boots, AFE Blade Runner intake, CNC HPOP lines, Banks Monster Turbo Back 4 inch, Billet Aluminum Plenums, ATS Boost Fooler, AFE Wastegate, Bellowed Up Pipes, Garret Powermax Ball Bearing Turbo, 160/30's, Moroso Pan, CnC 4 Fuel X-Over, CxRacing Intercooler Pipes. Coming next: ?? Wish list: Train horn, 4x4 conversion.
06 Mustang GT - GCC spec (Infidels May be closer than they appear) (SOLD)
16 Sonata Hybrid - Gas saver
Arizona_SVO is offline
post #9 of 11 Old 03-29-2017, 06:43 PM Thread Starter
toad's Avatar
Quoted: 27 Post(s)
Thank you for clarifying for me. Harness like this?
Putco Ford F-Series Headlight Replacement Harness - AutoTruckToys.com
toad is offline
post #10 of 11 Old 03-30-2017, 08:57 AM
Quoted: 25 Post(s)
This is the harness I got...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
