Is this 7.3L truck worth the money? - Page 3 - Ford Powerstroke Diesel Forum
 5Likes
post #21 of 34 Old 01-31-2017, 12:01 PM
ars5147's Avatar
Quoted: 211 Post(s)
A rust free non molested 7.3 up here in PA would bring that much at around 100k miles or less. But what makes a 7.3 here valuable is originality, like grandpa owned it, and no rust.
A truck with multiple owners who went nuts with cheesy stuff and advice from their idiot cousin who knows a guy that knows everything about diesels, is not that truck.
That truck is not worth $18,000. Just looking at it says it was slapped together with what ever parts the last owner or couple owners could get their hands on. Rusty bumper, some kind of semi tires on factory ford wheels on spacers, wtf?, un matched flares, 90s euro taillights, stick on chrome, etc. "Worth a lot more in parts than I am asking," just the wording of the post says walk away unless super cheap.
It's one of those trucks that only the owner could love haha, and now they want their money back b/c 7.3s are popular, but they don't realize it takes a certain truck to be worth 10 grand more than book values.
I'd pass unless this "super built" truck was SUPER CHEAP.
Name:	just look at it .jpg
1997 F350 CCLB 7.3
2019 F350 CCSB 6.7 Lariat Sport
ars5147 is offline
post #22 of 34 Old 01-31-2017, 12:10 PM
elephantrider's Avatar
Quoted: 205 Post(s)
not worth it. not even close.
ars5147 likes this.
02 joke
Originally Posted by djone10 View Post
I just bought an 05 powerstroke 6.0.
Any tips on what should be changed/checked other than oil change??
Originally Posted by Rolfsted View Post
Everything
elephantrider is offline
post #23 of 34 Old 01-31-2017, 05:49 PM
02_7.three's Avatar
Quoted: 66 Post(s)
Garage
x2 on what @ars5147 said. I picked up mine for about that much with 100k miles/ rust free with a 6 speed.
2002 F-250 ECSB ZF6
FF 205/30's, KC 63/73, South Bend Clutch, CNC Fab 4 Line Feed, AEM 400
02_7.three is offline
post #24 of 34 Old 01-31-2017, 06:32 PM
00t444e's Avatar
Quoted: 620 Post(s)
Its worth maybe half of that. I only paid 12K for mine with only 112,000 on it, and that was over three years ago.
00 f250 ext. cab, lb, 4x4, 170,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, KC 300x 63/73/.84 turbo, PHP Hydra, Riff Raff frx,, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, Edge CS2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #25 of 34 Old 02-01-2017, 08:33 PM Thread Starter
Quoted: 2 Post(s)
Thanks for all the good advice guys. Im going to go and look at the truck on Saturday morning. Unfortunately the lowest temperature we will hit that day will be 41 degrees so I've asked the seller to not plug in the block heater so that i can witness a coldish start.
Also the seller said the transmission is a Road Ripper 3000. Have you guys heard of this trans?
Im keep you guys updated on how it goes.
logan1 is offline
post #26 of 34 Old 02-01-2017, 08:37 PM
DieselDC's Avatar
Quoted: 682 Post(s)
I was serious about how ridiculous people are with their prices. Seller wants to trade for a 6.7 smh... good luck, let us know how it goes!
Sent from my iPhone using Tapatalk
DieselDC is offline
post #27 of 34 Old 02-02-2017, 05:58 AM
ars5147's Avatar
Quoted: 211 Post(s)
People plug stuff in at 40F there?
1997 F350 CCLB 7.3
ars5147 is offline
post #28 of 34 Old 02-02-2017, 06:45 AM
DieselDC's Avatar
Quoted: 682 Post(s)
Why would you ask him to unplug anything? Just ask him to leave it cold as is and you come there and monkey around with it?
DieselDC is offline
post #29 of 34 Old 02-05-2017, 08:11 AM Thread Starter
Quoted: 2 Post(s)
**UPDATE**
Well I went and looked at the truck yesterday. I decided not to buy the truck and here are my reasons why:
1) The owner had been running a DP tunner at it max setting for this daily driving.
2) The truck had 41" semi truck tires but the shift points for the automatic transmission were never adjusted to better work with the large tire.
3) The 8" lift was accomplished using two 3" blocks and one 2" block stacked in the rear and a set of four 1" blocks in the front.
4) The wheels are tires were never balanced. This caused the truck to ride with a good amount wobble down the street.
5) The motor was stock for the most part but had a K&N filter on it for most of its life.
6) The truck was on its original set of injectors and after cycling the glow plugs twice it took 3 attempts at cranking to start the truck at an ambient temperature of 43 degrees.
7) There was rust on the bottom of the rocker panels and the underside of the bed. The owner had sprayed expanding foam into the bottoms of fenders.
8) A new brake line was run to the rear axle using brass fitting from Home depot.
9) There was a lot of wire splicing going on with the harness.
Overall the truck looked tired and worn out and all the DIY mods looked very poorly done, The wiring in particular.
ars5147 likes this.
logan1 is offline
post #30 of 34 Old 02-05-2017, 08:16 AM
AMERICA!
Rattlesnake18's Avatar
Quoted: 1739 Post(s)
Feedback Score: 6 reviews
Why would you pass up a truck with a lift like that?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
