Why do the f250s have such a low GVWR? - Page 2 - Ford Powerstroke Diesel Forum
 1Likes
post #11 of 18 Old 01-27-2017, 06:51 AM
Quoted: 2 Post(s)
Originally Posted by gomer pyle View Post
Axle tubes are thicker on 350s.
Both 250 and 350 SRW's use the same Sterling axles. No difference. If you want to confirm that go to a Ford Dealer and have him look up the part #'s for each. Now duallys ARE different with the Dana 80.
2016 F 250 FX4 CC
Wolf Hunter is offline
post #12 of 18 Old 01-27-2017, 07:59 PM
Quoted: 28 Post(s)
Feedback Score: 3 reviews
Take a torch and cut the tubes on a few. I have seen hundreds from different makes and models. You wouldn't believe the different thicknesses.
gomer pyle is offline
post #13 of 18 Old 01-28-2017, 06:23 PM
gone6.0's Avatar
Quoted: 31 Post(s)
Originally Posted by Wolf Hunter View Post
Sounds like something out of California!!!!
yea they have changed the laws so many times here, on lifted trucks.
2004 F250, SCSB, APR studs, Banks intercooler, Edge Insight, SCT with tune from Eric, atlas 40, deleted, 2" leveling kit, coolant filter, 6.4 banjo bolts with blue spring, Harpooned, Nathan K5LA. Nations 190 amp alt.
Twin Viair 480C's. BOSS superduty 8' poly plow.
gone6.0 is offline
post #14 of 18 Old 01-28-2017, 06:29 PM
gone6.0's Avatar
Quoted: 31 Post(s)
yea and now they have the new bigger tow hitch, which increases the load rating, this does not make a lot of sense, just increasing the hitch size a little and still have the same truck, with different weight ratings
gone6.0 is offline
post #15 of 18 Old 01-28-2017, 06:45 PM Thread Starter
00t444e's Avatar
Quoted: 620 Post(s)
I think they both come with the same hitch, the convectional tow ratings are the same.
00 f250 ext. cab, lb, 4x4, 170,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, KC 300x 63/73/.84 turbo, PHP Hydra, Riff Raff frx,, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, Edge CS2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #16 of 18 Old 01-29-2017, 09:16 AM
gone6.0's Avatar
Quoted: 31 Post(s)
sorry I should have mentioned i was meaning from the older trucks with the 2" to the now 2.5".
the truck has not changed much, but the bigger receiver, means more load.
if just changing the hitch size can change load values, You could do this to a older truck.
but legally you cannot change what the factory has set.
gone6.0 is offline
post #17 of 18 Old 01-29-2017, 11:53 PM
alaskan155's Avatar
Quoted: 111 Post(s)
actually you can....
you can register any vehicle at a higher GVWR....
and the GAWR on a F250 are greater than the factory GVWR.....
ive have had 92 gallons of diesel in the bed and my trailer fully loaded before
not mine, but same ratings....
Im under GCWR of 20,000lbs, under/at axle ratings, (2 5200lb rated axles on trailer).
over hitch rating (tongue was 2k lbs, can be fixed with a upgraded aftermarket hitch, super hitch and curt both sell one rated that high)(had to empy trailer out, was overloaded)
and technically GVWR(doesn't matter)
but i am 100% legal
the GAWR on these trucks 10484lbs combined, the 8800 is just to cover fords legally.....
if i went by GVWR i would only have 800lbs to carry in a f250(8k with me and full tank)..... not happening captain
http://www.curtmfg.com/part/15810
they sell it in a 2" version. one of my next upgrades.....
2002 F250 7.3/JW Tow master 4r100 223k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH/EBPV delete, CNCfab HPx and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
DLR
alaskan155 is offline
The Following User Says Thank You to alaskan155 For This Useful Post:
gone6.0 (01-30-2017)
post #18 of 18 Old 02-01-2017, 12:27 AM
Quoted: 42 Post(s)
Garage
So, it just doesn't add up. The frames are the same, the axles are the same, the springs are the same, the wheels and tires are the same, the drivetrain is the same, and most importantly the brakes are the same. The only difference is the block in the back and that's an 1100 difference in GVWR. It must be a marketing thing for Ford. Perhaps a way to pluck a few hundred extra bucks for the folks who want to pay it.
Raising the rear of the truck a couple inches could increase payload a bit because the weight stays a bit better distributed, but for folks towing with a 5th wheel or weight distribution bars, I can't see it making any difference.
I may add a leaf if I ever feel the need for frequent heavy towing, but since I pull 12k lbs once every few years for a military move, I'm just going to overload the truck (legally) and get the job done.
ChrisArnold is offline
