2000 F350 power issues - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By 930dreamer
post #1 of 5 Old 02-13-2020, 08:06 PM Thread Starter
930dreamer's Avatar
Quoted: 23 Post(s)
Hello,
I'm having acceleration, stumbling, power issues. When cold low speed acceleration is a problem i.e no smooth speeding up, cuts in/out. When warm same issues trying to hold a steady speed but with cruise on no issues. 7.3 has 261k on it and not a 4x4.
930dreamer is offline
post #2 of 5 Old 02-13-2020, 10:47 PM
SuperCrutyPS's Avatar
Quoted: 657 Post(s)
Garage
Have you checked the truck's accelerator pedal assembly? Try unplugging the connector and spraying some contact cleaner in the pedal connector and the connector on the cable.
I had to replace my assembly because I was getting a dead pedal right after starting the truck and sometimes it would go dead in traffic. I could put the truck in neutral, stomp on the pedal, it would come back. If I cleaned the connector, it would act normal for a week or two. Since the new pedal assembly, it's been working great.
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB |
5th Wheel |
Proud US Navy Veteran | '76-'80 -
- 'Gator Navy
SuperCrutyPS is online now
The Following 2 Users Say Thank You to SuperCrutyPS For This Useful Post:
930dreamer (02-14-2020)
post #3 of 5 Old 02-14-2020, 04:43 AM Thread Starter
930dreamer's Avatar
Quoted: 23 Post(s)
I'll give that a try and thank you.
post #4 of 5 Old 02-14-2020, 07:42 AM
Quoted: 476 Post(s)
Feedback Score: 3 reviews
At your mileage, you may well be seeing the end of your injector life (they're Original?)
See if plugging the block heater in for 2-3 hrs before your Cold Start completely changes the way it runs...
NoRalPh is offline
post #5 of 5 Old 02-14-2020, 11:01 AM Thread Starter
930dreamer's Avatar
Quoted: 23 Post(s)
I cleaned the contacts in both plugs and the micro switch, all issues gone. This forum is the bomb and thank you.
SuperCrutyPS likes this.
