Intermittent Turbo Piston Seal Leak - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-18-2020, 10:38 PM Thread Starter
Quoted: 4 Post(s)
Curious if anyone has dealt with a turbo seal leaking intermittently, on either exhaust or comp side?
Ie truck smokes when cold, but stops when warm.
newobs is offline
post #2 of 7 Old 01-19-2020, 05:47 AM
7.3_TurboDiesel's Avatar
Quoted: 132 Post(s)
Sounds like an injector to me. Does it start ok cold without being plugged in?
Sent from my iPhone using Tapatalk
7.3_TurboDiesel is offline
post #3 of 7 Old 01-19-2020, 11:45 AM Thread Starter
Quoted: 4 Post(s)
Yeah other than smoke. Issue was the same before so I also figured injectors. But with only like 12-15k on the 238/80's, injectors were pulled have been flowed by FFD and 1 nozzle replaced. 8 new Ford/Beru GP's, and new Western GPR were installed as well.
Wondering if perhaps this is just related to tuning, on the larger injectors? I cannot go to a stock tune, because the injectors are singles on a split pcm.
newobs is offline
post #4 of 7 Old 01-21-2020, 01:10 PM
Quoted: 132 Post(s)
Who’s tunes do you have?
post #5 of 7 Old 01-25-2020, 03:18 AM
AgInternational's Avatar
Quoted: 7 Post(s)
Sounds similar to what I've got, the smoke part. My injectors are stock sized though and have been in for 20k now.
Sent from my moto x4 using Tapatalk
2000 F350 7.3L CC LB 6 speed manual 4x4
391,000 miles and counting
Always fixing it...
AgInternational is offline
post #6 of 7 Old 01-25-2020, 11:10 AM Thread Starter
Quoted: 4 Post(s)
Swamps Tunes, 6 or 7 years.
If I didn't have single shots, I would remove the chip to see if it is a tuning issue.
Anyone know how I can run singles with stock tuning, on a split pcm truck?
I've considered it to be a tuning issue, as I have heard others say. I've seen videos online, of trucks with these size injectors running clean, so I know it can be done. Just a matter of who's tunes it is I guess.
Turbo does have what feels to be a ton of side to side play, not too much in and out. No contact with housing. It does not feel normal whatsoever, but then I have heard that these t4's may have wider bearing clearances, so as long as it doesn't touch I am good.
The truck did this same thing before I sent the injectors to be checked by FFD, and replaced with new orings. I'm considering sending injectors to another place to see if they show the same.
Before I do that I am gonna go through and check all injectors for level, oil flow, and hot torque everything.
newobs is offline
post #7 of 7 Old Today, 05:48 PM Thread Starter
Quoted: 4 Post(s)
Bump.
Pulled turbo didn't find oil in exhaust side.
Hot torqued injectors at 120+.
Any other ideas guys?
newobs is offline
