Whishhhh noise when cold.. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-13-2019, 04:50 PM Thread Starter
Quoted: 14 Post(s)
I noticed this first about a week ago.
When cold, and night time / eve temperatures are in the 20s, the motor makes a jet like whishhhh type noise at LOW throttle. I can punch through what ever this is by heavy throttle and loading the engine.
But you return to low throttle and again get the whishhh thing.
When punching through, you also notice a power come back. As if its weaker during the whishh noise.
When the engine is thoroughly warm, this goes away.
Also, you know how if you let a vehicle wam up at idle, sometimes the idle bumps up 100-150 rpm? Then you tap the accelerator and it falls back to a normal idle?
Well, now it seems to make the noise during the high idle, sounds normal during low idle.
This sound seems to be comming from the exhaust pipe.
groundhogy is offline
post #2 of 5 Old 11-13-2019, 05:39 PM
Quoted: 405 Post(s)
Garage
That is the Exhaust Back Pressure Valve -- basically a flapper to restrict the exhaust -- it helps the engine warm up faster
The EBPV is supposed to open up if you accelerate -- and when warm it should be open
possible the temp sensor is bad or the wiring to the actuator is worn thru
it is located in the turbo mounting base -- take a look at the harness and linkage to the actuator
The idle thing is also part of the warm up
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 5 Old 11-13-2019, 06:07 PM Thread Starter
Quoted: 14 Post(s)
I just watched a video of a guy the rigged his to an on/off switch in the cab. He flipped it on and off... his 7.3l was making the same noise that i am hearing.
(Didnt i take that sensor off when i did my HPOP?)
post #4 of 5 Old 11-13-2019, 07:03 PM Thread Starter
Quoted: 14 Post(s)
So is this an emergency level thing?
Or is it something that can wait?
I am going to be moving my RV from PA to TN shortly.
post #5 of 5 Old 11-14-2019, 07:53 AM
JustinOOO9's Avatar
Quoted: 1628 Post(s)
Garage
Feedback Score: 3 reviews
Its an oem pieice designed to help "accelerate warm up" most just delete it, rig It, or some kits can turn it into a diy exhaust brake. Many delete it because too be honest it doesn't do squat and the plunger arm can leak oil etc. One word of advice. if you delete it get a garret brand non ebpv turbo pedestal. Don't mess with aftermarket ones trying to save $20. All can be bought on riffraff diesel, cnc fab, and most other sites.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
