engine that loses these cylinders - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-01-2019, 05:33 AM Thread Starter
Hello
I explain my concern about the powerstroke.it starts very well then after a time (no time or temperature report) it starts to lose cylinders and then leaves on these 8 or hold.
sometimes leaves without worries or sometimes does not leave until 2 or 3 days later.
i do not have a default injection code just the exost pressure that is not compliant.
I own the forscan to make measurements.
If you have any ideas ...thank you
silvery11 is offline
post #2 of 4 Old 09-02-2019, 07:59 AM
7.3_TurboDiesel's Avatar
Quoted: 101 Post(s)
The cam position would be my first guess
Sent from my iPhone using Tapatalk
7.3_TurboDiesel is offline
post #3 of 4 Old 09-02-2019, 08:07 AM Thread Starter
Thank you
above was changed the camshaft sensor, the icp and the exhaust pressure sensor (but still a fault on this side P0476).
post #4 of 4 Old 09-15-2019, 09:00 AM
Quoted: 3 Post(s)
Garage
Did you clean out the EPB tube? What are the EBP values?
BioSteve is offline
