7.3 issue - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 13 Old 06-26-2019, 07:17 PM Thread Starter
7.3 issue
This just started this morning when I went out to start the truck to go to work. The wait to start light went out and I turned the key to start it up, but it cranked and cranked without firing up. I went through the process of the wait to start another time and the same thing. During the coldest part of the winter it rarely did this so now that summer is here Iím not sure what is going on. After the forth time it started and ran fine, but did the same thing after work. Any suggestions would be greatly appreciated.
Robert W Sorensen Jr. is offline
post #2 of 13 Old 06-27-2019, 01:35 AM
jonathanh96's Avatar
Quoted: 16 Post(s)
Originally Posted by Robert W Sorensen Jr. View Post
This just started this morning when I went out to start the truck to go to work. The wait to start light went out and I turned the key to start it up, but it cranked and cranked without firing up. I went through the process of the wait to start another time and the same thing. During the coldest part of the winter it rarely did this so now that summer is here I’m not sure what is going on. After the forth time it started and ran fine, but did the same thing after work. Any suggestions would be greatly appreciated.
If you have torque or another system to monitor Icp post your PID results, if not
Try unplugging your icp and see if it starts.
'02 F-250 7.3
180/80% Stage 2 Full Force Injectors
S&B Intake
Hydra running Gearhead Tunes
5" Straight Pipe
Bellowed Up-Pipes
Bilstein 5160 Resi's
Rough Country Dual Steering Stabilizer
etc, etc
jonathanh96 is offline
The Following 2 Users Say Thank You to jonathanh96 For This Useful Post:
Robert W Sorensen Jr. (06-28-2019)
post #3 of 13 Old 06-27-2019, 04:15 AM
00t444e's Avatar
Quoted: 550 Post(s)
Check the oil level.
7.3_TurboDiesel likes this.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #4 of 13 Old 06-28-2019, 06:27 PM Thread Starter
I will try that tomorrow morning.
post #5 of 13 Old 06-28-2019, 06:29 PM
Quoted: 339 Post(s)
Garage
Could be several things, did the engine sputter or otherwise run "odd" when you finally got it started?
anything from a fuel pressure issue to low injection oil pressure -- don't think electrical since it did start, but don't rule that out yet
Have you done anything to the truck lately? service, mods, etc
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #6 of 13 Old 06-28-2019, 06:53 PM Thread Starter
I disconnected the icp and still doesn’t start. I don’t have any of the scanners or the ability to borrow one to use, but I was hoping to try to fix this myself, any other thoughts would be much appreciated, and I did check the oil level which is right where it should be.
post #7 of 13 Old 06-28-2019, 07:00 PM Thread Starter
Once the engine did start it stalled right away and then started again and ran fine, it is my only driver so it’s getting a little harder each time and I only use it to go back and forth to work. I was wondering if the fuel was losing prime? But I really don’t know the system that well, I’m only a back yard mechanic, and most of that was always gasoline engines, so I’m learning quickly about diesels now. No modification what so ever, just changed the oil and filter, but not the fuel filter this time. I did try disconnecting the ICP and starting it then and it still didn’t start, the ICP was clean with no oil evident on the end at all.
post #8 of 13 Old 06-28-2019, 09:09 PM
SuperCrutyPS's Avatar
Quoted: 602 Post(s)
Garage
How old are your batteries? I had some batteries closer to the end of their usefulness. My truck would crank, but not start. Repeat, it would. When the batteries got weaker, it wouldn't start. There is a lot of stuff needing power during startup that's one of the reasons we have two.
Something to check.
Darryl | Owner/Operator
Truck | 2001 F350 CCLB
5th Wheel |
Proud Veteran | US Navy - '76-'80 - Petty Officer 2nd Class (E5)
SuperCrutyPS is offline
post #9 of 13 Old 06-28-2019, 10:21 PM
Quoted: 602 Post(s)
Garage
BTW - I merged your two posts into one. Don't need two post saying the same thing. Please keep your discussion here.
5th Wheel |
post #10 of 13 Old 06-28-2019, 11:35 PM
Quoted: 16 Post(s)
Try unplugging the IPR (back of HPOP) this should set it to default setting. Sometimes no starts/running rough could be a faulty IPR.
in addition to that, may also be your cam position sensor which are notorious for going out and leaving you stranded. You can get to that underneath your vehicle.
'02 F-250 7.3
S&B Intake
5" Straight Pipe
Bellowed Up-Pipes
etc, etc
