bad iat cause a crank no start - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-21-2019, 03:07 PM Thread Starter
Krazykimber's Avatar
Quoted: 2 Post(s)
after hubby changed injector o rings we have a crank no start my codes are p0113 p0603 n p1280 so will a bad iat sensor cause it to not start
Krazykimber is offline
post #2 of 13 Old 05-21-2019, 04:57 PM
7.3lf550's Avatar
Quoted: 60 Post(s)
It should not cause any issues unless it is messing with the 5v ref circuit. Just unplug it. Truck will run without it.
03 7.3l 550, FRx, 6637 mod, 4 inch turbo back, ccv delete, aih delete, HPx, Riffraffs OCR, Turbo-pyro-boost-coolant EV2 gauges, Bullydog GT tuner.
03 X 6.0 175/30 warren sticks, Livewire TS w/ warren tunes, Blue spring mod, atlas 40 ficm, 270amp dc power alt
Originally Posted by Heavy_GD View Post
goats lives matter.
7.3lf550 is offline
post #3 of 13 Old 05-22-2019, 05:58 AM
Quoted: 407 Post(s)
Feedback Score: 3 reviews
More likely that 1280...
Have you cranked it enough? If the HiPres Oil system is full of Air (because you've removed the injectors and drained the rails) it takes some time to purge out through the injectors themselves.
Your 1280 says you have Low pressure in the system.
NoRalPh is offline
post #4 of 13 Old 05-22-2019, 01:19 PM Thread Starter
Quoted: 2 Post(s)
yes the hubby has primed it that's what my husband thought was wrong with it losing its prime... he has pushed air thru the fuel pump fuel bowl filling up everything like it should now we he puts a shot of starter fluid"(I know terrible thing to do....)" on it it will start for a brief second n die again
post #5 of 13 Old 05-22-2019, 01:20 PM Thread Starter
Quoted: 2 Post(s)
on the scanner its shows map sensor 0hz and the air intake temperature -40°
post #6 of 13 Old 05-22-2019, 01:23 PM Thread Starter
Quoted: 2 Post(s)
either I dont know how to operate this scanner or I gotta buy software to do a buzz test I think that will tell me if injectors are all working because this all happened due to the hold down bolt for the injector broke n the injector came out hitting the valve cover truck started bucking n shut off n dumped fuel behind the exhaust
post #7 of 13 Old 05-22-2019, 04:06 PM
Quoted: 407 Post(s)
No, no, no,,, you misunderstand me. This is Not about Fuel it's about the HiPres Oil that drives the injectors. You introduce Air into the system and it can take considerable cranking to replace that air with oil (often needs to be drive 50-100mi, once running, to purge it all).
Starting Fluid is a big issue, especially with a working GP system. Either use something else (break cleaner etc.) or disable your plugs.
NoRalPh is offline
post #8 of 13 Old 05-22-2019, 04:51 PM Thread Starter
Quoted: 2 Post(s)
so is there a way to purge the hpop... he has been cranking it for days now
post #9 of 13 Old 05-22-2019, 04:56 PM Thread Starter
Quoted: 2 Post(s)
here is the scan I was able to get
ID:	719095   Click image for larger version
post #10 of 13 Old 05-22-2019, 05:04 PM Thread Starter
Quoted: 2 Post(s)
this is the scan that I did
ID:	719101   Click image for larger version
ID:	719103   Click image for larger version
Similar Threads
Thread Thread Starter Forum Replies Last Post
95 7.3 crank won’t start, starts with ether, dies at idle Owen Daniel 94-98 7.3L Problem Forum 3 07-23-2018 05:21 AM
2001 7.3 Crank No Start, No WTS Light, No Fuel??? GraysonM 99-03 7.3L General Discussion 6 03-29-2018 03:39 PM
05 6.0 starts cold, crank no start when hot waistline00 6.0 Motor problems 68 08-07-2017 01:58 PM
Will start when cold, No Crank when hot jstofan 6.0 Motor problems 1 07-28-2017 09:14 AM
Feel like i've been taken for a ride. Don't know what to do. 1950Allis General 6.0L Discussion 264 05-01-2017 04:28 AM
