Massive oil leak from passenger's rear of engine - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 24 Old 09-06-2018, 02:53 PM Thread Starter
Quoted: 11 Post(s)
Hey guys,
For those who don't know me, I'm the idiot that decided to put a T444E from a school bus into my truck. That I just bought with a bad engine because someone changed the oil to flush the gallons of coolant out of the crankcase right before I looked at it.
Fast forward a week and a half of fighting with the truck and a tremendous amount of regret, and it's back together with a slightly more fresh engine. 114K miles from a school bus with rust and a slipping transmission. Went to fill it up with oil, and noticed that it dripped oil from the flywheel inspection cover. Important detail number one. Not a ton of oil, but a definite drip that stopped pretty much immediately after I stopped adding oil.
Everything else looked good, so I fired it up. Started pretty quickly for an engine that hadn't run in forever. Shut it off pretty much immediately after it found idle, as I hadn't filled the radiator, anticipating something going wrong and having to take it all back apart. Looked under the truck, and it was gushing oil. Like if you turned a quart bottle upside down. Said some choice words, put a drain pan under it, and called it a night.
Today, there's probably at least a quart and a half of oil in the drain pan. I started it back up on the lift, let it start to leak, and shut it down and ran the lift up. It's leaking in a steady stream from what looks like the passenger's side rear corner of the oil pan. Now, in the T444E swap, the oil pan is one of the things that has to be swapped over, so the pan was off. I also don't have a engine stand capable of turning this engine upside down, so I had to do it right side up which is a no-no according to International. But I did it as right as possible under the circumstances. The pan was removed, the mating surfaces rigorously cleaned, and the engine was left to drip for several days. Cleaned every day with brake clean to prevent as much oil contamination as possible. It went back together with the TA31 sealant, as per International. Even so, I didn't expect it to be perfect, though I can guarantee that it's far from the worst oil pan job done on these engines. Figured that a slow leak was better than a big orange paperweight taking up room in my shop.
My first thought seeing this leak was that the seal failed, but with the amount of oil that is leaking, I don't think it's possible for it to be the pan seal unless there's something else going on. There would have to be a large hole and a ton of pressure in the crankcase for it to leak this much from between the pan and the mating surface. Again, multiple steady streams. So my next thought was rear main seal. Like an idiot, I didn't replace that when I had the engine out. But again, unless there's a huge chunk of the seal that's just gone, I can't imagine it leaking this much.
What's throwing me off is that it leaked when filling with oil. A lot of the common leaks on this truck don't seem compatible with the way it's behaving. Turbo o rings can't leak when filling, since there's no oil going in that direction when the engine is off. Rear main would be unlikely to leak when filling. Oil pan shouldn't leak when filling, since it would have to navigate the thick layer of sealant, along with the fact that the pan is bolted against the mating surface, while under no pressure at all. Cracked cylinder shouldn't leak when filling.
So my question is, what is on this engine that would A) leak in a steady drip when adding oil to an empty crankcase B) leak like a garden hose when running, even after a few seconds and C) leak from the rear passenger's side corner of the pan.
Hopefully someone has some suggestions, because I've spent pushing 4 grand and a week and a half of labor to have a truck that I still can't drive.
Thanks in advance for any advice.
Redlineauto is offline
post #2 of 24 Old 09-06-2018, 03:04 PM
SuperCrutyPS's Avatar
Quoted: 628 Post(s)
Garage
Engine off:
Are you sure the filler neck piece is intact? Could it be cracked in some way or not seated properly on the valve cover so to leak oil while filling?
Engine on:
Have you checked the Valley of the engine? There is a weep hole near the back of the engine that will allow oil from the valley to run down the back of the engine. It could look like it's dripping from the pan.
So...if the valley has oil in it, you could have a leak from the HP oil lines running to the heads or a leak at the turbo pedestal or maybe the HPOP itself.
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB
5th Wheel |
Proud US Navy Veteran | '76-'80 - Petty Officer 2nd Class (E5) - U.S.S. Point Defiance (LSD-31) - 'Gator Navy
SuperCrutyPS is offline
post #3 of 24 Old 09-06-2018, 03:15 PM Thread Starter
Quoted: 11 Post(s)
Originally Posted by SuperCrutyPS View Post
Engine off:
Engine on:
Thanks for the fast reply. The filler neck is intact, and I would expect to see it leak while filling. Valley is relatively dry, and the only thing up top that I would think could leak this much would be if an hpop line was completely open. I'd estimate that it lost a quart of oil and roughly 5 seconds of running.
post #4 of 24 Old 09-06-2018, 07:25 PM
Oil dipstick on the side of the pan? That wouldn't explain it coming down the back though....
Sent from my SAMSUNG-SM-G891A using Tapatalk
tda271 is offline
post #5 of 24 Old 09-06-2018, 08:06 PM Thread Starter
Quoted: 11 Post(s)
Nope, dry as a bone.
This all seems very odd to me. I can't think of anywhere that would leak this much and yet also leak when filling through the filler tube. It's enough volume that it seems like a completely disconnected hpop line, but it can't be anything out of the path of oil flow from the filler when not running.
post #6 of 24 Old 09-06-2018, 08:26 PM
Quoted: 628 Post(s)
Garage
All the bolts in the valve cover on that side? Valve cover not pushing down enough on the gasket?
5th Wheel |
post #7 of 24 Old 09-06-2018, 09:06 PM Thread Starter
Quoted: 11 Post(s)
I'm gonna go back and double check tomorrow, but pretty confident that they're all well torqued and intact.
post #8 of 24 Old 09-07-2018, 09:08 AM Thread Starter
Quoted: 11 Post(s)
Valve cover bolts are nice and snug. No leaking there.
post #9 of 24 Old 09-07-2018, 10:02 AM
Quoted: 461 Post(s)
Feedback Score: 3 reviews
And there's No Chance this is Fuel ~ right? (common to have the metal supply line chafe at the clamp back there...)
NoRalPh is offline
post #10 of 24 Old 09-07-2018, 10:35 AM Thread Starter
Quoted: 11 Post(s)
100% confident that it's oil.
