2001 7.3 stalling new ford cps no CEL - Ford Powerstroke Diesel Forum
post #1 of 39 Old 09-04-2018, 07:59 AM Thread Starter
Quoted: 23 Post(s)
Im having a problem with my truck stalling at idle after its warmed up for a bit, it starts right up afterwards and doesnt throw a CEL code when it stalls. In the morning it does sometimes have CEL light on but when i go to read it with the torque pro app it goes away. Before it stalls the rpms will usually flutter a little bit like go up then drop to about 500 so not sure if its the tps or something. I just replaced the crank sensor with a ford oem one (grey one) although i found out afterwards the black ones can work better, also changed the fuel filter. Every time i try to scan it the code goes away so does anyone have any ideas? any help is appreciated. Thank you.
nick1993 is offline
post #2 of 39 Old 09-04-2018, 08:07 AM
DieselDC
DieselDC's Avatar
Quoted: 677 Post(s)
Injectors worn
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
DieselDC is offline
post #3 of 39 Old 09-04-2018, 08:09 AM
White_Buffalo7.3's Avatar
Quoted: 170 Post(s)
Garage
Harness under valve cover
180/30s,KC38R, CNC Fab Stg 2 HPOP, Sump, Walbro, Donaldson 6637, Leveled, 4'' straight to 7'' tip, 08 mirrors, 6.0 front end ect...
White_Buffalo7.3 is offline
post #4 of 39 Old 09-04-2018, 08:47 AM
Quoted: 407 Post(s)
Feedback Score: 3 reviews
Make sure your Torque App is properly configured (you don't use it out-of-the box)
Read through this about your app -> https://www.powerstroke.org/forum/99-...sis-cheap.html
It makes No Sense to me to be making wild guesses when you see, even a "disappearing", code that can direct you to a problem
NoRalPh is offline
post #5 of 39 Old 09-04-2018, 10:09 AM Thread Starter
Quoted: 23 Post(s)
ok, i just set it up to read ipr and icp readings, im hoping its something with one of those sensors
nick1993 is offline
post #6 of 39 Old 09-04-2018, 10:12 AM
Quoted: 170 Post(s)
Garage
How many miles you got?
post #7 of 39 Old 09-04-2018, 10:22 AM Thread Starter
Quoted: 23 Post(s)
its got 263000
nick1993 is offline
post #8 of 39 Old 09-04-2018, 10:23 AM Thread Starter
Quoted: 23 Post(s)
not sure if injectors have already been replaced or not, ICP doesnt have any oil in it when i unplugged it to check
nick1993 is offline
post #9 of 39 Old 09-04-2018, 11:23 AM
Quoted: 407 Post(s)
Soooo, what are your #'s (IPR/ICP) before/after it starts to "flutter" on you, And,,, what were the codes you found?
NoRalPh is offline
post #10 of 39 Old 09-04-2018, 11:26 AM Thread Starter
Quoted: 23 Post(s)
I just set it up a few minutes ago so ill read it once i get done work, but it won't read the codes, it just scans it and the code clears. The scanner does work because i used it on my fathers 7.3 to pull a code so not sure why it dissappears when i read it, ive read some people have said the grey cps can cause some trouble and to get the blue one from international, im hoping to get somewhere looking at the ipr and icp numbers tongiht
nick1993 is offline
