Faint Blue Smoke - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-17-2018, 02:48 PM Thread Starter
Faint Blue Smoke
I just bought a 2000 7.3l yesterday knowing that it needed work, the original owner said he had it offroad and it started smoking and parked it. i test drove it and it puts out some blue smoke but pretty faint. i am not new to the 7.3 diesels but am still learning, i can post pictures and videos since i know that'll help you guys but im not sure when i can get that since i dont have it parked where i live. Here is what ive done so far
1. took the oil cap off and put it upside down and it seemed like it just vibrated off the filler tube with the smoke coming out in a small solid cloud and not puffing and dissipating fairly quickly.
2. doesnt seem to have a lack of power on acceleration puts out a small blue cloud that dissipates pretty quick but hard to tell cause it puts out quite a bit of black smoke, which it supposedly doesnt have a chip but it does have new injectors a couple years old that im not sure if theyre stock or bigger.
3. wife followed me home and said it smells like a burnt charcoal smell when i accelerated also said it puffed out some white smoke anytime i accelerated but dissapated fairly quick
4. two things i found is a gasoline oil bottle in the engine bay not sure what weight it is as most of the label is gone so could that be it if he used engine oil? also the air filter is really dirty and im pretty sure he unfortunately bought a washable k&n filter that will be replaced with the tymar filter not sure if that'd cause it as well.
5. my old neighbor thats helped me before said that it could be caused by the motor not getting up to normal operating temp. which it ran about midway between the start of the normal temp and the middle of normal, not sure if that is a normal range for this year of these motors
6. the turbo has no shaft play but i noticed the compressor wheel had a black coating on it in the center also when i took off the top of the air filter housing it had smoke coming out of it from the turbo
7. last not sure if itll help but the oil pressure gauge assuming its not a dummy gauge like my 96 showed that it was above half way on the gauge reading the entire way home
thanks for any help guys i do appreciate the advise i get on here.
Stroked96 is offline
post #2 of 2 Old 07-02-2018, 10:38 PM
jonathanh96's Avatar
Quoted: 19 Post(s)
Sorry to bump an old thread but doesn't seem like OP got much attention.
Typically in my experience
Blue smoke = burning oil
Black smoke = partially burnt fuel
White smoke = raw fuel
Now you mentioned an oil bottle In the engine bay. If it isn't the proper weight it could be causing oil to get past the rings which would cause the blue smoke.
Honestly I would take it to a diesel shop that specializes in ford, the truck will need to have several tests done to it to zero in on the problems. I could try to guide you but by the time you get the issue fixed without diagnostic equipment you would've probably paid more than the labor to diagnose.
'02 F-250 7.3
180/80% Stage 2 Full Force Injectors
S&B Intake
Hydra running Gearhead Tunes
5" Straight Pipe
Bellowed Up-Pipes
Bilstein 5160 Resi's
Rough Country Dual Steering Stabilizer
etc, etc
jonathanh96 is offline
