2000 F350 7.3 Won't go Over 50 mph - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 21 Old 04-12-2018, 08:21 PM Thread Starter
Quoted: 7 Post(s)
I have a 2000 7.3 powerstroke that is sluggish with acceleration. Today I went pick up a 40 ft gooseneck and the truck was accelerating even slower. I drove about 70 miles and the truck didnt go over 55 mph even with the accelerator all the way to the floor. Going up a bridge the truck went from 55 mph to 25 mph. The motor runs fine at idle, no knock or misfire. No check engine light. Please help!!
Roman985 is offline
post #2 of 21 Old 04-13-2018, 06:36 AM
White_Buffalo7.3's Avatar
Quoted: 191 Post(s)
Garage
check that your getting boost. if you have a boost leak for a boost sensor leak the MAP will not let your truck fuel properly. if it doesn't see boost. you don't get fuel.
180/30s,KC38R, CNC Fab Stg 2 HPOP, Sump, Walbro, Donaldson 6637, Leveled, 4'' straight to 7'' tip, 08 mirrors, 6.0 front end ect...
White_Buffalo7.3 is offline
post #3 of 21 Old 04-13-2018, 06:44 AM Thread Starter
Quoted: 7 Post(s)
When you say check the boost. How exactly can I check the Boost?
Roman985 is offline
post #4 of 21 Old 04-13-2018, 06:50 AM
Quoted: 191 Post(s)
Garage
Well, either with an actual boost gauge(usually how you create the leak) or by using an OBD2 gauge.
You can get the "Torque" app and monitor things through there just as long as you buy the Bluetooth OBD2 thinger. Do you have a freind that you can borrow a Edge, or an SCT from and monitor you boost?
post #5 of 21 Old 04-13-2018, 06:52 AM Thread Starter
Quoted: 7 Post(s)
No. Would a regular obd2 scan tool work the same?
Roman985 is offline
post #6 of 21 Old 04-13-2018, 06:52 AM
Quoted: 191 Post(s)
Garage
Also, here is the link to a bluethooth OBD "scanner"
https://bafxpro.com/products/obdreader
Then, you will need the Torque app, it costs 10 bucks on the app store but if it'll help you get over 55MPH, kinda worth it.LOL
post #7 of 21 Old 04-13-2018, 06:53 AM
Quoted: 191 Post(s)
Garage
Sadly, no, they can't monitor real time gauges or parameters like boost, all they do is read a code
post #8 of 21 Old 04-13-2018, 06:55 AM Thread Starter
Quoted: 7 Post(s)
So the scanner that you sent me in the link and the app is the only to things that i would need?
Roman985 is offline
post #9 of 21 Old 04-13-2018, 06:59 AM
Quoted: 191 Post(s)
Garage
Yup, should be about $30 total. Watch some YouTube videos on how they work so you know and then if it seems doable,
post #10 of 21 Old 04-13-2018, 07:02 AM Thread Starter
Quoted: 7 Post(s)
Thanks man I really appreciate it, so that's the only problem you think it could be?
Roman985 is offline
