Diiferential fluid leak - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-06-2018, 05:28 AM Thread Starter
wilbur9a's Avatar
Just acquired a '99 F250 with 7.3L and 27,000 miles. Rear differential has a leak (slow drip, brown-tan color, thick, and smells like oil) but the origin is from the top front driver side of differential, not from a seal below. Tag on the rear of the differential is marked as "" S 409 E L 73 105 9 F 03 "" .
ID:	683274   Click image for larger version
ID:	683282   Click image for larger version
wilbur9a is offline
post #2 of 3 Old 04-21-2018, 08:47 AM
jamierayo's Avatar
Quoted: 9 Post(s)
It looks like its leaking from the speed sensor. It has an o-ring & 1 bolt that holds it in. The code trys you its a limited slip with 3.73 gears.
His:
1999.5 F350 XLT Crew Cab Dually Flatbed 4x4 7.3L
PHP Hydra, S&B Intake, MBRP 4" Exhaust, Gauges, Harpoon mod, Hutch mod, 6.0 Cooler, Airbags, 08 Mirrors, Brush Guard w/2 9" HID's & 2 4" Lightforce, 100 gal Transfer Tank
Hers:
2003 Excursion XLT 4x4 7.3L
PHP Hydra, S&B intake, MBRP 4 Exhaust, SPX 5+5 Wheel, Gauges, 6.0 Cooler, 08 Mirrors, RAS, Timbrens
jamierayo is offline
post #3 of 3 Old 04-25-2018, 08:14 AM
Wood's Powerstroke's Avatar
Quoted: 125 Post(s)
Garage
Send a message via Skype™ to Wood's Powerstroke
Yep; Locker with 3:73's. I agree that it looks like it's leaking from the speed sensor on top. Clean the housing with brake cleaner, unplug the sensor, remove the one bolt (10 mm, I believe) and GENTLY pry it out. Replace with a new sensor, and happy motoring. A '99 with only 27,000 miles? Man, you hit the jackpot. Post a pick or two.
Wood's 7.3
Old School Strokin'
2001 F-250, 7.3 Powerstroke
Lariat, 4X4 Off-Road, Crew-Cab, SB, AT
Wood's Powerstroke is offline
