Sensor on rear of HPOP reservoir - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-21-2019, 05:01 PM Thread Starter
Quoted: 2 Post(s)
I have a 97 f250HD. I was wondering what the sensor is on the rear of the HPOP reservoir on drivers side? It is about midway down.
dave97f250 is offline
post #2 of 3 Old 10-21-2019, 07:50 PM
1Dieselman's Avatar
Quoted: 221 Post(s)
Feedback Score: 4 reviews
That is not a sensor, it is the IPR, (injection pressure regulator) it is controlled indirectly by the ICP (injection control pressure) sensor on the valley side of the drivers head near the front
Jack
_______________________________________________
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
323000 miles
1Dieselman is offline
post #3 of 3 Old 10-22-2019, 07:27 AM
Patrick Feeley's Avatar
Quoted: 80 Post(s)
There is also the Engine Oil Temperature (EOT) in the same general area. Cheers!
Patrick Feeley is offline
