96 psd cranks but will not start - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-06-2011, 09:03 PM Thread Starter
Hi ive got a 1996 powerstroke diesel with a starting issue, it all started about a month ago it became very and i me mean very! slugish when cold to the point of almost not being driveable. Once it warmed up it was fine off idle but when idleing it had a significant miss. I had been driving it this way for about a month because of the long hours i work at my job i didn't have the time to troubleshoot it. well this morning i didn't have time to let it warm up jumped in it got about a mile down the road and it cut out and now will crank but not start. here's what i know and have checked:
: checked all the maxi fuses
: replaced cps recently so i doubt that's it
:no smoke from tailpipe
:wait to start light does come on
:fuel pump appears to be working
:I have also noticed that the engine valley back by the turbo is filled up with a little bit of diesel.
:i know this is not good for it but when a little ether is applied to a rag and draped over the air intake it will run for a second off of the ether
ive norrowed it down to a few things i think it is. Tell me what you guys think: It's either my IPR, ICP, or PCM. I am not new to diesels but new to PSD diesels. Any help on how to troubleshoot these items or any other theories you might have would be greatly appreciated, Thanks!
Last edited by coalroller 96; 09-07-2011 at 07:14 AM. Reason: incorrect forum 94-98 7.3 l problem forum
coalroller 96 is offline
post #2 of 2 Old 09-07-2011, 12:18 AM
You have posted in the wrong spot go down a few
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
