1995 7.3 powerstroke no start,no wait to start light - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-06-2019, 05:32 PM Thread Starter
Quoted: 2 Post(s)
Hi I have a 95 7.3 5spd with ts6 chip and it died as I was driving one day went to restart and no wts light came on nothing from tachometer no fuel smoke nothing replaced idm and pcm still no wts light,no start(tryed without chip first then with) check and replaced all fuses under the hood got nothing also replaces valve cover gaskets,pig tails and glow plugs
Trucks been sitting really wanna drive it again please help 🙂
7point3turbo is offline
post #2 of 9 Old 12-06-2019, 08:02 PM
Quoted: 17 Post(s)
Why are you spending so much money when you don't know what's wrong with it? Need to first get a code reader so you can have a starting place instead of just guessing.
timlsalem is offline
post #3 of 9 Old 12-06-2019, 08:11 PM Thread Starter
Quoted: 2 Post(s)
I tried hooking a scanner on it. It wouldn't communicate with the pcm
post #4 of 9 Old 12-07-2019, 03:46 AM
Quoted: 326 Post(s)
If condition was unknown of the replaced parts then it still didn't hurt to replace them.
I'd double check all the fuses with a multimeter.
The sudden dying can be caused by the fuel bowl heater grounding out or another electrical short.
You can get a bluetooth adapter and download Car Gauge Pro to an Android device and connect to the PCM that way.
A scanner is the best option at this point. Also verify the PCM was replaced with the correct unit.
White95f250 is offline
post #5 of 9 Old 12-07-2019, 04:38 AM Thread Starter
Quoted: 2 Post(s)
I did all 12 volts fuel bowl and ebpv are unplugged and I replaced all fuses about 2 times lol
post #6 of 9 Old 12-07-2019, 06:16 AM Thread Starter
Quoted: 2 Post(s)
And it's the same one just rebuilt but I will check fuses one last time as well
post #7 of 9 Old 12-07-2019, 06:28 PM
Quoted: 17 Post(s)
Maybe check all your ground wires. One loose wire will kill the motor instantly and will probably affect the WTS light too.
post #8 of 9 Old 12-07-2019, 07:09 PM Thread Starter
Quoted: 2 Post(s)
I will give that in the morning I'll let you k ow how that dose me
post #9 of 9 Old 01-05-2020, 01:27 PM Thread Starter
Quoted: 2 Post(s)
Update guys there was 2 wires pitched under the dash
