Edge CTS 2 Shutting Off Randomly - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By BajaSurfRig4.0
post #1 of 8 Old 10-30-2019, 03:14 PM Thread Starter
Hi Guys,
I installed a Edge CTS 2 with a EFT probe a year ago in my 96 F350 and it works great about 80% of the time....
The screen will go black at random times (around 20% of the times I start the truck) and stay off for my whole drive.
When I touch the screen while driving after it shuts off, it will reboot and then turn off again.
I have already spoke with Edge and they have sent me the most up to date software.
Any ideas what this could be?
Bad OBD2 Port?
Bad Ground Somewhere?
My mechanic can't figure it out and I am sick of pulling over and restarting the truck to get the Edge to reset (so I can see my EGT's while towing)
Thanks!
96 F350 7.3 E4OD 4x4 237K
BajaSurfRig4.0 is online now
post #2 of 8 Old 10-30-2019, 03:38 PM
jokester00's Avatar
Quoted: 481 Post(s)
Garage
Are you monitoring battery voltage? I do know if the system voltage gets below a certain value, they will power themselves off.
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is online now
post #3 of 8 Old 11-06-2019, 11:24 AM Thread Starter
@Jokester
I am monitoring voltage on my CTS and on the stock gauge on the dash and haven't seen anything out of the ordinary.
When the CTS does shut off it is usually pretty soon after starting the truck.
Could be something to do with the glow plugs turning off?
I have cleaned the connections with both batteries and just installed fresh batteries in the truck.
Does anyone have any ideas on where to troubleshoot this?
jokester00 likes this.
post #4 of 8 Old 11-08-2019, 08:09 AM Thread Starter
Could this be a bad ground issue at either the chassis ground (#4 pin on OBD2) or sensor ground (#5 pin on OBD2)?
I will check both of these this weekend and write an update here after...
post #5 of 8 Old 11-08-2019, 08:40 AM
JustinOOO9's Avatar
Quoted: 1616 Post(s)
Garage
Feedback Score: 3 reviews
if im remembering your model is the touch screen right? Edge hasn't released anything official but the touch screen models do not play well with the OBS trucks ecm. I've known numerous people who went to the previous model with buttons and it works just fine. I don't understand the technical aspects but I imagine it just takes more ram/memory/power or something to run the touch screen vs button type etc.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is online now
post #6 of 8 Old 11-08-2019, 02:36 PM Thread Starter
@Justin 0009 mine is the touch screen version...
I hope you are wrong about this as the unit was not cheap.
I chose it over gauges, because of the back up camera and the ability to read codes.
post #7 of 8 Old 11-08-2019, 03:28 PM
JustinOOO9's Avatar
Garage
I have been using edge products for 10+ yrs. 99% they work great but for some reason a great deal of OBS trucks don't work well with the touch screen units. I don't feel its edges fault though. They work on 90% of the cars and trucks that have an OBDII port and its just 20+ yr old computers working with newer stuff. Kind of like windows not supporting windos xp and so on etc. Two friends have nearly the identical problems you did. One deals with it, the other got the button version like I have and no more issues etc.
post #8 of 8 Old Today, 02:08 PM Thread Starter
I am hoping to not have to ditch the CTS2 as it wasn't cheap and won't be worth that much used....
When I was driving yesterday my edge showed my batteries at 0 volts, but the gauge on the dash showed 13.5 or so.
When I restarted the truck the edge read the battery voltage as 13.5 again.
Any idea what that could mean? Is that related to my problem?
Tags
edge cts 2
