7.3 ticking/knocking - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-20-2019, 01:53 PM Thread Starter
Sky Staudenmayer's Avatar
I got this 1996 7.3 powerstroke about a month ago, but I don't know if I'm being paranoid or not thinking that the engine sounds like it's ticking or knocking a bit too much, can some of you guys tell me if you think I'm being paranoid or if not what I should start checking to fix? It does have 350,000 miles on it, but it was well maintained, I have a 3in binder full of Maintenance records. It doesn't have a loss of power and everything works like it should. I'm sure it needs injectors soon which I'll be working on as soon as I have money to do so. Here's a video of it running:
https://photos.app.goo.gl/7x39gXtXf4qUBTiv6
I also wanted to ask about any fuel additives to quiet the injectors and help Lube stuff up in general?
Sky Staudenmayer is offline
post #2 of 6 Old 07-20-2019, 01:56 PM
MSM
MSM's Avatar
Quoted: 19 Post(s)
Garage
Sounds fine to me. I have a 2000.
MSM is offline
post #3 of 6 Old 07-20-2019, 09:12 PM
Quoted: 327 Post(s)
Opposite, that sounds healthy and idles good. Makes many of us jealous.
White95f250 is offline
post #4 of 6 Old 07-21-2019, 09:34 AM Thread Starter
Thank you! That's good to hear, I think it might be more of me being paranoid because I got it for 3700....
post #5 of 6 Old 07-21-2019, 10:40 AM
Quoted: 485 Post(s)
Garage
Sounds like a lifter tick, but hard to tell -- not as common on the 7.3 as is on the 6.0
I would want to run the engine with the valve covers off and use a stethoscope to pin point the tick -- if any
with that many miles I prolly would just replace the lifters and pushrods for good measure
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
post #6 of 6 Old 07-21-2019, 11:04 AM Thread Starter
I'll definitely look into it here soon, especially if it gets louder, thank you!
