No WTS light, no tach, no start, dead pedal. - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 15 Old 06-19-2019, 11:58 AM Thread Starter
camshaftwillie's Avatar
No CEL. What happens when IPR is stuck open? Where does oil go?
camshaftwillie is offline
post #12 of 15 Old 06-19-2019, 12:52 PM
Patrick Feeley's Avatar
Quoted: 87 Post(s)
If stuck open oil will be directed back to the crankcase. Cheers!
Patrick Feeley is online now
post #13 of 15 Old 06-19-2019, 01:17 PM Thread Starter
Awesome. Thank you!
post #14 of 15 Old 06-19-2019, 04:55 PM
Quoted: 527 Post(s)
Garage
Remove the ICP sensor and crank the engine over -- should squirt oil out, that will let you know if the hpop can pump oil
Fuel pump running?
Need a monitor to see what the PCM is reading -- Torque Pro , Forscan or others
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #15 of 15 Old 06-20-2019, 07:12 AM Thread Starter
OBS. Mechanical pump there. I’ll try that with a plug out of the rail. It won’t start or hit at all with ICP unplugged
Similar Threads
Thread Thread Starter Forum Replies Last Post
No wait to start light bluemaruder001 99-03 7.3 Motor Problems 5 01-10-2018 04:40 PM
No Start, Jumping tach wertycade 94-98 7.3L General Powerstroke Discussion 3 01-02-2018 10:53 PM
Dead pedal going down the highway today chaselee General 6.7 Discussion (2011-2016) 5 01-24-2017 07:46 PM
Check engine light and flashing wait to start light Kshow 94-98 7.3L General Powerstroke Discussion 6 10-18-2009 01:39 PM
Wait to start light doesn't turn on-truck wont start! jrny93 99-03 7.3 Motor Problems 6 12-28-2006 04:48 AM
