1995 F250 PS won't pull fuel from rear tank - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-07-2019, 05:07 PM Thread Starter
The previous owner ran biodiesel in the rear tank so I suspect there's gunk in the line from the rear tank before the FSV. If I switch to the rear tank the truck starts to sputter/choke and eventually dies.
Assuming there's gunk in the fuel tank filter (or some other issue?) how could I clear that out without dropping the tank? Is it possible to somehow inject warm/hot diesel? Or maybe a chemical I could put in the tank that would disolve a clog?
I haven't tried blowing high pressure air into the tank yet from the hose connecting to the FSV.
The truck drives fine on the front tank so I know the issue is not between the FSV and the fuel bowl.
I've never dropped a tank before and am hoping I don't have to do that.
Any ideas?
powerless-stroke is offline
post #2 of 4 Old 04-07-2019, 06:47 PM Thread Starter
well hot **** damn! I got off my lazy *** and blew out the line and it probably cleared those gooey filters. I'm back in biznuss!
post #3 of 4 Old 04-07-2019, 07:14 PM
Patrick Feeley's Avatar
Quoted: 69 Post(s)
What level is the rear tank? The "shower heads" in the tanks like to disintegrate and the pieces can cause problems in the selector valve and lines. The problems will usually show itself at about 1/4 tank. Cheers!
Patrick Feeley is offline
post #4 of 4 Old 04-07-2019, 10:28 PM Thread Starter
Hey Patrick, it was full when I troubleshot it today. I got hung up when this issue popped up over a year ago and have been running off the front tank. I pumped out all of the diesel to take a look (year ago), and added a fresh batch. The truck just randomly seized up on me one day a year ago but I cannot remember if I was near empty or full at that time. Probably near empty.
Hey, so I'm probably going to need to replace those parts. Is dropping the tank easier than lifting off the bed? I think I might rather rig up a hoist and pull off the bed if that's possible. I've never done either.
Similar Threads
Thread Thread Starter Forum Replies Last Post
6.4 fuel additive questions 1macarr General 6.4L Discussion 26 02-19-2019 10:12 AM
2011 Ford F350 P228F. Hunter6146!! 6.7 Tech Files (2011-2016) 3 10-16-2018 05:25 PM
Front Fuel Tank Fuel Level Defective BigDude97 94-99 7.3 Repair Help 0 10-02-2017 04:21 PM
Motor life straight up answer el conquistador 94-98 7.3L General Powerstroke Discussion 37 10-14-2008 07:23 AM
auxiliary fuel tank dinkydau 99-03 7.3L General Discussion 5 08-14-2006 05:36 PM
