Steering issue - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-23-2019, 09:01 AM Thread Starter
Steering issue
So I just bought a 97' crewcab F350 2wd and one thing I have noticed is there is a lot of slack play in the steering wheel. I have to turn the wheel at least 1/8 to 1/4 turn before it will start turning the wheels. What could this possible be? It did bug me a little bit when I first hopped in it to take it home and I'd like to figure out the issue or issues if there is more than one. This is my very first Powerstroke ever owned let alone a Diesel motor pickup. All of my previous vehicles have been gas motors.
The_Texas_Bandit is offline
post #2 of 5 Old 03-23-2019, 09:19 AM
Quoted: 317 Post(s)
Garage
Someone needs to turn the steering wheel back and forth while another looks under the truck to see where the slack is. I wouldn't feel comfortable driving the truck until this was done.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 5 Old 07-16-2019, 06:27 AM
Quoted: 2 Post(s)
Sounds like a wore out steering box. Quarter turn is a lot of play. You didn't say how many miles are on the old girl,but that much play indicates to me a steering box issue. Like Hydro says have a look see under rig.Good luck!
garyeco is offline
post #4 of 5 Old 07-30-2019, 10:01 PM
Garage
I also just picked up a '97. Mine has very tough steering at slow speeds. Haven't driven it anywhere yet because it's so bad. My first thought is the pump, but I'm curious if the box could also be a potential issue here.
XTexasJoryX is offline
post #5 of 5 Old 08-06-2019, 08:57 AM
worn out midshaft?
You may find the midshaft in the steering column has play in it. I had that on my F350 before I rebuilt it. The midshaft sits between the steering column and the steering gearbox. Not too hard to reach or remove. It has a telescoping feature that allows it to collapse in the event of a front end collision. To keep these two parts of the shaft 'snug' to each other, there is a plastic bushing between the two of them that can deteriorate over time. When it deteriorates, it can introduce significant play into the steering, even BEFORE you get to the steering box...... as recommended above, you might have one person turn the steering wheel, while the other checks where the play is occurring......
If it's your steering shaft, you can take your chances at an auto wrecker (I found a few good replacements), or you can buy OEM replacement at a number of distributors, and I even understand there are excellent aftermarket options available too (I believe Flaming River has a splined shaft that'll have no chance for play anywhere)
Cheers
cason234 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Memory Steer.. Steering Box? Bri_Man57 99-03 7.3L General Discussion 42 10-12-2018 06:29 PM
6.0 power steering issue tjames07 6.0L Problems Forum 0 10-26-2017 06:38 PM
Boost issue? HELP!! Stoney.Jacobs 6.7 Motor Problems (2011-2016) 2 10-26-2017 08:49 AM
Steering Literally Won't turn sitting still colonel angus General 6.0L Discussion 7 02-23-2017 04:52 PM
TCS Dash Light Issue - PLEASE HELP! DieselRiley35 6.4 Drivetrain Problems 4 11-15-2016 06:58 PM
