DIY injectors nozzles for 7.3? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-12-2019, 08:10 PM Thread Starter
I’ve done a lot of reading into DIY injector modifications and I am pretty set on that route as I have access to a professional machine shop and machinist who can do the work for me. Im familiar with the modifications needed to change the injector itself to a larger cc however I am looking to see if nozzles could be modified as well. I am aiming to replicate full force 180cc/80% stage 2s. I know Nozzles can be bought standalone but I figured I could save myself $400 and have some more DIY satisfaction. I’m sure it’s not too difficult, I have just never had a larger nozzle to compare to a stock one to see what needs to be done. If anyone could help me out with some measurements and/or pictures it would be greatly appreciated!
Pwagner014 is offline
post #2 of 9 Old 06-13-2019, 03:43 AM
Quoted: 307 Post(s)
Do you have a way of checking flow rate? If not, then it will be hard work wasted.
White95f250 is offline
The Following 2 Users Say Thank You to White95f250 For This Useful Post:
02_7.three (06-13-2019)
post #3 of 9 Old 06-13-2019, 05:15 AM
White_Buffalo7.3's Avatar
Quoted: 191 Post(s)
Garage
I dont quite remember his user name but that guy with a guy supercharger on his 7.3 home brewed some 350/200s. I'm sure he could give you some pointers. Its eaton something
180/30s,KC38R, CNC Fab Stg 2 HPOP, Sump, Walbro, Donaldson 6637, Leveled, 4'' straight to 7'' tip, 08 mirrors, 6.0 front end ect...
White_Buffalo7.3 is offline
post #4 of 9 Old 06-14-2019, 11:22 AM Thread Starter
I have read about dozens of people who have machined their own intensifier pistons without checking the flow and have had no issues. I’m not afraid of that by any means and worst case I just buy some nozzles. The parts are mechanically identical. If the injector isn’t worn out, it will flow the same as the next.
post #5 of 9 Old 06-14-2019, 11:31 AM
Heavy_GD's Avatar
Quoted: 3138 Post(s)
Garage
Feedback Score: 4 reviews
@SuperchargedPSD
https://www.powerstroke.org/forum/94...0-nozzles.html
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #6 of 9 Old 06-14-2019, 11:34 AM Thread Starter
@SuperchargedPSD
Thank you!
post #7 of 9 Old 06-14-2019, 12:04 PM
Quoted: 307 Post(s)
"Mechanically identical"
Man you should come work with me for a day. That will have a whole new meaning.
It's your truck so you can do what you want how you want. I'd like to see the results. The DIY injector rebuilds took a dive after a bunch of people screwed them up and went after the parts manufacturer etc.
post #8 of 9 Old 06-16-2019, 06:47 AM
066
066's Avatar
Quoted: 10 Post(s)
I had a place in California extrude hone my nozzles for about $25/each
06 6.0 King Ranch Work Truck
ARP Studs
IPR Remote Oil Cooler
IPR Coolant Filter
KC Stage 2 Turbo
175/30 Injectors + Atlas 40 FICM
BD Up Pipes
Performance Radiator
5" Diamond Eye Exhaust
Gearhead Tunes
HID Retrofit
066 is offline
post #9 of 9 Old 06-16-2019, 01:09 PM Thread Starter
Forgive me, nozzles is the part I am still pretty unfamiliar with, what does that get you? Basically my question is how much meat do I need to remove to make 80% injectors
