Electric Fuel Conversion - Ford Powerstroke Diesel Forum
post #1 of 95 Old 12-06-2018, 10:36 PM Thread Starter
LovesDunes's Avatar
Quoted: 3 Post(s)
This happened a while ago, but all of the pictures were lost when the hosting site went down. I am finally done rebuilding the thread. Well, almost.
I've read a lot of threads on the electric fuel conversion on various sites so I thought I would show everyone what I did in case it can help someone else. I also ended up removing the EBPV and replacing the HPOP. There is some jumping around from one thing to another but it finally gets done.
So I had a small fuel leak for a while and no time to fix it since I have been so busy with work. Well the mechanical pump finally gave up. So for the second time in it's life my truck got a ride home...
Things won’t look like this for long…
1997 F-350 4x Crew Cab Long Bed.
425,000+ Miles
LovesDunes is offline
post #2 of 95 Old 12-06-2018, 10:37 PM Thread Starter
LovesDunes's Avatar
Quoted: 3 Post(s)
With the turbo and intercooler tubing removed you can see the fuel pump and the mess it's made...
425,000+ Miles
post #3 of 95 Old 12-06-2018, 10:38 PM Thread Starter
LovesDunes's Avatar
Quoted: 3 Post(s)
The hardest thing about removing the turbo was just getting to it. The one thing I donít like about the truck being tall. No special tools needed at least.
425,000+ Miles
post #4 of 95 Old 12-06-2018, 10:38 PM Thread Starter
LovesDunes's Avatar
Quoted: 3 Post(s)
I removed the pedestal and took apart the EBPV to see what was inside.
It looks like I had a leak at the down pipe...
I definitely had an oil leak where the rod comes out of the housing for the EBPV...
Maybe it's the o-rings under the pedestal or the EBPV but it looks like a leak over here too...
425,000+ Miles
post #5 of 95 Old 12-06-2018, 10:39 PM Thread Starter
LovesDunes's Avatar
Quoted: 3 Post(s)
Removing the pedestal was easy enough. Just the four 10mm bolts at the bottom...
Linkage on the end has a cool spring loaded dealeo...
It was easy to remove...
O-Rings in between the turbo and pedestal...
425,000+ Miles
post #6 of 95 Old 12-06-2018, 10:40 PM Thread Starter
LovesDunes's Avatar
Quoted: 3 Post(s)
The pedestal was a mess...
425,000+ Miles
post #7 of 95 Old 12-06-2018, 10:40 PM Thread Starter
LovesDunes's Avatar
Quoted: 3 Post(s)
The EBPV (Exhaust Back Pressure Valve) came apart easy enough.
Remove the snap ring...
A little tapping on the link from the other end...
The dust seal wasn't doing too great a job...
The inside of the housing was full of crud...
The rubber seal in the picture was as hard as a rock. That might explain the oil leaking out the hole where the linkage exits...
Since I have never seen the inside of the turbo housing I took it apart too...
I'm not sure how this electrical thing works. It's mounted to the pedestal...
425,000+ Miles
post #8 of 95 Old 12-06-2018, 10:41 PM Thread Starter
LovesDunes's Avatar
Quoted: 3 Post(s)
It took me a bit to get the fuel bowl and the fuel pump off.
The rubber fuel lines were reeaalllly hard and didn't want to let go of the metal lines so I ended up just cutting through the rubber lines.
After cutting those I thought it was going to come out. But the one at the bottom didn't want to let go either...
It was harder to cut with the lack of space but this blade made it easier...
425,000+ Miles
post #9 of 95 Old 12-06-2018, 10:42 PM Thread Starter
LovesDunes's Avatar
Quoted: 3 Post(s)
So I got the fuel bowl almost out but I found these wires still holding on...
This one pulled right off...
Whatever that one wire was plugged into unscrews...
So that this thing can be rotated clockwise...
And pulled from the bowl...
But even pulling those loose would not let me pull the fuel bowl from the truck. The plugs would not slip through this hole...
So I ended up cutting the wires to get the fuel bowl out...
425,000+ Miles
post #10 of 95 Old 12-06-2018, 10:42 PM Thread Starter
LovesDunes's Avatar
Quoted: 3 Post(s)
I took the fuel pressure regulator off of the bowl just because. You can see the screen that people are always saying to clean...
Mine was nice and filthy...
I took the bottom apart to see what was inside...
There is some sort of screen filter looking thing in there and of course itís dirty too...
425,000+ Miles
