php tunes vs custom tunes for daily driver/ tow rig - Page 2 - Ford Powerstroke Diesel Forum
 3Likes
post #11 of 22 Old 04-11-2018, 09:58 AM
1Dieselman's Avatar
Quoted: 222 Post(s)
Feedback Score: 4 reviews
Originally Posted by sprayed347 View Post
Corey how important are guages? i got the money for the hydra but not the guages this is a daily driver that tows a race car trailer on weekends.
The most important gauge is the egt. 1250* is the max you should allow for a extended amount of time. A boost gauge is great for troubleshooting if you start to see a problem with reduced power. Boost and egt go hand in hand when a problem starts to show. Trans temp in a automatic is something you should keep an eye on when towing heavy especially in heavy traffic, mountain terrain, or very hot climates. Anything above 240* is getting to hot
[email protected] likes this.
Jack
_______________________________________________
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
323000 miles
1Dieselman is offline
post #12 of 22 Old 04-17-2018, 08:56 AM Thread Starter
sprayed347's Avatar
Quoted: 11 Post(s)
dont really care for the a-pillar guage look its not a race truck by any means can the torque app be used with these trucks or is the info that is monitored by these old truck useless.
sprayed347 is offline
post #13 of 22 Old 04-17-2018, 09:01 AM
00t444e's Avatar
Quoted: 612 Post(s)
You can't monitor egts with the torque app because there is no sensor and the boost will only read to 24 PSI since that is as high as the map sensor will read. I don't recommend putting a chip on it unless you have a way to monitor egts, boost, and trans temp if it's an auto.
00 f250 ext. cab, lb, 4x4, 170,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, KC 300x 63/73/.84 turbo, PHP Hydra, Riff Raff frx,, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, Edge CS2, 4 in diamod eye straight pipe 6 in tip.
00t444e is online now
post #14 of 22 Old 04-17-2018, 09:10 AM Thread Starter
sprayed347's Avatar
Quoted: 11 Post(s)
oh well looks like its gotta get pillar guages.... thanks guys!!
post #15 of 22 Old 04-17-2018, 09:21 AM
JustinOOO9's Avatar
Quoted: 1679 Post(s)
Garage
Feedback Score: 3 reviews
The wicked wheel 2 turbo wheel will help with towing too. you can install it at home in a couple of hours and was a nice addition for towing.
I added the 6.0l trans cooler and reduced trans temp 25+ degrees empty and towing
I added a john woods custom valve body helped firm and quicken shifts a lot.
I got a nice deal on a used ww2 wheel and the shift kit cost me like $245 plus shipping my core back and then changing the trans fluid and filer maybe 7-8 quarts. Overall a very nice set up for towing with daily driver feel too. I don't run tunes very much anymore not that they don't help but I have a very rare ecm code and php, 1023, and few others just have a lot of trouble with the shifting on it. I had to have custom tunes done and still waiting on a revision from php. 1023 hasn't emailed me back since December of 2017 so that's pretty much a lost cause. Dan from SDK made some tunes for a buddies truck and I really liked the shifting for the tow and eco tunes.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #16 of 22 Old 04-21-2018, 05:43 AM
Quoted: 46 Post(s)
No, there are other options for gauge locations. I never liked the light bar look of A pillar gauges. There are pods for locating gauges below the dash and above the rear view mirror. I didn't choose those because you lose sight of the road ahead anytime you check them. Not good. I choose a Auber brand instrument. It's duel channel, square and mounts great just right of the diesel lights. Mine displays EGTs and fuel pressure. What each channel senses depends on the sensor you choose for each? AND, it has many user adjustable parameters and auxiliary contacts.
97 F350 XL std cab, zf5, srw (converted), 4wd, 3.55s, stock wheels/tires & rebuilt 9.18
2 Donaldsons, 3" dp, ACs, T500, HV LPOP, Hydra w/PHP, DIY 60 gl tank w/6 gl sump, eFuel/Cat filters, Aeromotive RR, Auber instruments, 140v IDM, KC 300X 63/70/84, boost fooler, RiffRaff bellowed up pipes, 6.0 IC, 3" plenums w/RiffRaff inserts & SB 425HD
MeTo is offline
post #17 of 22 Old 04-25-2018, 10:26 AM Thread Starter
sprayed347's Avatar
Quoted: 11 Post(s)
got any pics of that?
post #18 of 22 Old 04-25-2018, 01:50 PM
Quoted: 46 Post(s)
It's not a great pic, but you get the idea. Red is EGTs and green is fuel pressure. Boost pod is on the steering column. That was a waste of money; I use it as an economy meter.
Name:	Auber Instrument.jpg
MeTo is offline
post #19 of 22 Old 12-21-2018, 10:46 PM
Fubar72's Avatar
Ok can't send a pm
What type of sensor is used for fuel pressure? Where is it connected?
Sent from my SAMSUNG-SM-G890A using Tapatalk
Fubar72 is online now
post #20 of 22 Old 12-22-2018, 05:23 AM
Quoted: 46 Post(s)
I purchased the display, thermocouple (EGTs) and the pressure sender (fuel) from Auber Industries. I have efuel, so the pressure sender is in a port on the return regulator. With a stock fuel (fuel bowl) I would remove the schrader valve and put the sensor in there.
MeTo is offline
