1st Diesel block heater question - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 15 Old 11-12-2014, 06:41 PM Thread Starter
pk64f100's Avatar
This is my 1st diesel truck and it has a block heater when do most start using this and do you just keep it plugged in all the time during cold weather if driving daily? What temps is it reccommended to use? TY
1995 F350 CCLB ZF5 2x4, 10.25 w/410 posi, 305/65 R16's, SB Intake, TS 6 pos chip, Baby Swamps 150/146, Exhaust brake, Riff Raff Bellowed Up-Pipes, 3" DP w/ 7" Big-Rig exhaust. Garrett Exhaust Brake. Int- Leather bench front & rear
pk64f100 is offline
post #2 of 15 Old 11-12-2014, 06:49 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 7 Post(s)
Feedback Score: 4 reviews
I plug mine in below 40, but since I just put a gpr in this winter and glow plugs last winter I don't plug it in at all, it would be best to get a timer, set to come on about 2-3 hours before you go anywhere if it's setting over night, otherwise you just run up the power bill
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
The Following User Says Thank You to 351fifty For This Useful Post:
pk64f100 (11-13-2014)
post #3 of 15 Old 11-12-2014, 07:37 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
If you are needing to ask about block heaters, I presume Carroll county is someplace warm? You probably don't even need it.
I live where cold comes from. I use the block heater, a magnetic pan heater and have on occasion used a tiger torch through a section of exhaust pipe to warm things sufficiently.
Setting a timer to warm things a little if anywhere close to or below freezing certainly won't hurt though.
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #4 of 15 Old 11-12-2014, 08:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 7 Post(s)
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 15 Old 11-13-2014, 03:33 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
-JJ-
JJFLASH is offline
post #6 of 15 Old 11-13-2014, 05:25 AM
Heavy_GD's Avatar
Quoted: 3136 Post(s)
Garage
hahahaha... Well played Kris.
If you can plug it in, then do it.
I'm just south of you in Va, and if the temps are freezing over nite I'll plug it in and set the timer for 4 hours before I need to fire it up.
Timers are cheap and easy to find this time of year with all the xmas decor out.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
The Following User Says Thank You to Heavy_GD For This Useful Post:
post #7 of 15 Old 11-13-2014, 06:01 AM
I just installed new gpr and gp's last year. I honestly dont need to plug mine in at all. But i plug mine in when it gets a little below 40 or so, on a timer that kicks it on 3 hours before i leave for work. I only run 8 miles to work so having it plugged in even though it doesnt necessarily need it, helps the truck at least get up to a decent running temp.
Mark Phillips
96 f250
Reg cab longbed 2wd, lowered 4", FFD stage 1.5 180/30, wicked wheel, gearhead tunes, 3"dp, 4" straight from diamond eye, 6637, riffraff OCR, 17*hpop, zf5 swap, vailair, custom trac bars, efuel.
'10 tundra LTD 4x4
Onboard air, nathan air chime p3, rigid ind. Dually Floods.
Tri-State-Truckin is offline
post #8 of 15 Old 11-13-2014, 02:50 PM Thread Starter
pk64f100's Avatar
1st Snow heater working great!
Worked like a charm at low 30's after about 2 hrs warm started immediatelly. 1st snow showers today I guess JJ's weather blew south, thanks alot JJ!
pk64f100 is offline
post #9 of 15 Old 11-13-2014, 07:07 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
You are welcome. Enjoy. Lol
-JJ-
JJFLASH is offline
post #10 of 15 Old 11-13-2014, 07:20 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 7 Post(s)
Don't ya mean HO ho ho
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
