Fuel Pressure Regulator (FPR) Screen Writeup - Page 14 - Ford Powerstroke Diesel Forum
 1Likes
post #131 of 154 Old 03-04-2015, 07:04 PM
noisytrucks's Avatar
Thanks ya.
noisytrucks is offline
post #132 of 154 Old 03-05-2015, 06:34 AM
Thumbs up
Originally Posted by noisytrucks View Post
Thanks ya.
No problem
CELAYORK is offline
post #133 of 154 Old 07-05-2015, 01:07 PM
bvmbandit's Avatar
FPR Screen
Just finished cleaning my FPR screen and found a substance that was the consistancy of old dried grease over the entire screen and also found a sliver of trash in the little hole under the screen as well. Cleaned it out completely and well see what this cleaning does along with the BB mod on the regulator.
bvmbandit
1997 OBS 7.3 289000 miles and counting HD 4 door 2WD
bvmbandit is offline
post #134 of 154 Old 07-06-2015, 08:15 AM
bvmbandit
First
You will notice some difference in the engine performance. Wich is the actual fuel pressure with the mod?
CELAYORK is offline
post #135 of 154 Old 09-19-2015, 07:53 AM
how do you do this on a 1996. I loosened the 2 10mm and there's solid fuel line? In the front at bottom Is that pressed in ? Thanks
shawpdx1 is offline
post #136 of 154 Old 11-23-2015, 12:10 PM
away's Avatar
Is this on the 2000-2001 models as well?
2000 Ford Excursion
2001 F-250 Crew Cab Short Wheel Base
Pulling Trucks for
Drag Racing
1978 mustang II 363 CI SBF
1972 Maverick 532 CI BBF
away is offline
post #137 of 154 Old 05-24-2016, 11:15 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
So I went ahead and did this yesterday. There was a good 1/8th inch of crap on the screen. I cleaned it off and changed the o-ring and reinstalled it. I also took off the EBP sensor and cleaned it and cleaned out the tube and reinstalled them. Truck runs much better. Definitely a noticeable improvement in sound and response. I have no idea if there is a mileage gain but I will find out here shortly.
One issue that I did encounter though is now when i go to slow down and the TC unlocks the RPM's dip real low resulting in the truck having to catch itself and in one case it actually died but it did start right back up.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #138 of 154 Old 05-24-2016, 12:45 PM
Quoted: 330 Post(s)
Mine bogged too when I first bought it. Could be VSS or BPS. Vehicle Speed Sensor or Barometric Pressure Sensor.
White95f250 is offline
post #139 of 154 Old 05-24-2016, 02:54 PM
the baconator
terryknight's Avatar
Quoted: 182 Post(s)
holy **** ryan's back. and now in AK, last i knew you were in VA
Ryan Rønning likes this.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #140 of 154 Old 05-24-2016, 03:46 PM
Quoted: 6 Post(s)
Ya I tend to get around. Living in Wasilla and working Anchorage these days. Glad to be back on the ORG!
