7.3 regulated fuel supply - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-27-2020, 08:11 PM Thread Starter
jtshop4@gmail.com's Avatar
Quoted: 5 Post(s)
So the 6.0 powerstrokes have a regulated fuel supply and not a regulated return. I know our Trucks need a regulated return but what would happen if you also put a regulator to the supply lines? Would it run better, or worse? Would it just screw stuff up? I'm building my own efuel system and have an option of having the supply lines being regulated to about 45psi instead of about 6psi (isn't it?) to the heads.
post #2 of 2 Old 01-28-2020, 03:24 AM
Quoted: 330 Post(s)
We have a 2 stage mechanical pump. One side sucks from the tank and the other side compresses to the heads.
You need the pump mounted closest to the tank and your regulator in the valley set to 55-60psi with the return line going back to the tank.
White95f250 is offline
