Fuel bowl hole? Cant see what the hole is from - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-17-2019, 05:06 PM Thread Starter
Quoted: 2 Post(s)
Alright so we are facing the truck. Take off the fuel filter in the bowl. Bottom of the bowl on tjr bottom left I see a hole that someone expoxy something in it. So I pull at the glue and found a perfectly machined hole. It's not the fuel bowl heater. I had to throw expoxy back into it to seal it. Fuel bowl hole?  Cant see what the hole is from-0810191750_1568768711566.jpg
Kevron Hoffman is offline
post #2 of 6 Old 09-17-2019, 06:04 PM
Quoted: 358 Post(s)
Garage
" It's not the fuel bowl heater."
Your correct the heater has been removed -- that is the hole for the wire connector
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 6 Old 09-17-2019, 06:44 PM
Patrick Feeley's Avatar
Quoted: 79 Post(s)
Was the epoxy the brown stuff in the first picture? That looks like something with the fuel bowl drain valve. Check out this link from Diesel O-Rings: https://www.dieselorings.com/docs/OB...owlRebuild.pdf
Cheers!
Patrick Feeley is offline
post #4 of 6 Old 09-17-2019, 07:04 PM Thread Starter
Quoted: 2 Post(s)
Fuel bowl heater was disconnected and unplugged before picture was taken.
post #5 of 6 Old 09-17-2019, 07:11 PM Thread Starter
Quoted: 2 Post(s)
The brown stuff is the glue that was in there. I thought it was the drain but the drain works when I turn the valve to drain it.
post #6 of 6 Old 09-17-2019, 07:29 PM
Quoted: 358 Post(s)
Garage
You sure?
see attached pic
Name:	7.3-hpop-removal-replacement-drain-remove-fuel-bowl-valve-nipple-lines-heater-plug.jpg
General note:
Last edited by Hydro; 09-17-2019 at 07:39 PM. Reason: After looking at it more, I cant tell what that hole is for from the camera angles
Hydro is offline
