97 f350 no start - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-24-2019, 09:45 PM Thread Starter
Jordan Finfrock's Avatar
97 f350 no start
need help I'm ready to pull my hair out. started the truck up one day was letting it idle and just like that the truck shut off. will not start. there was a ground wire on the left side kick panel that was not grounded at the time but now it and still no start. I have tach movement, wait to start light comes on, hpop is full, fuel bowl fills and all fuse are good. I cant connect to obd port because it says can not connect to ecm. NEED HELP!
Jordan Finfrock is offline
post #2 of 11 Old 08-25-2019, 06:47 AM
greenskeeper's Avatar
Quoted: 299 Post(s)
pull each valve cover...I bet you have a faulty UVCH. Look for burnt wiring on the harness on both heads, also while you have the valve covers off confirm oil is coming from all 8 injectors while cranking indicating they are firing.
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD 203K all original
99 F-250 CC 4x4 7.3L PSD ZF6 253K all original
greenskeeper is offline
post #3 of 11 Old 08-25-2019, 08:44 AM
Patrick Feeley's Avatar
Quoted: 85 Post(s)
Is the CEL illuminated? What are you trying to use to connect to the PCM? Most generic scan tools cannot connect to these trucks. Cheers!
Patrick Feeley is offline
post #4 of 11 Old 08-25-2019, 09:28 AM Thread Starter
im using a snapon solus edge and the cel goes illuminate
post #5 of 11 Old 08-26-2019, 03:33 AM
Quoted: 326 Post(s)
Check all fuses? CPS?
White95f250 is offline
post #6 of 11 Old 08-26-2019, 09:53 AM Thread Starter
yeah all fuses are good and I have tach movement
post #7 of 11 Old 08-26-2019, 11:25 AM
Quoted: 326 Post(s)
Any smoke while cranking? If not then a buzz test is in order and HPOP and fuel pressure needs to be checked while cranking.
post #8 of 11 Old 08-27-2019, 06:26 PM Thread Starter
I have no smoke but I can't get any scan too to connect to test anything
post #9 of 11 Old 08-27-2019, 07:03 PM
Quoted: 326 Post(s)
A bluetooth adapter and an android device with Car Gauge Pro app will do everything you need.
No smoke means injectors aren't firing. Either no fuel pressure, no HPOP pressure and/or no signal to fire.
At this point you can point to IDM or possibly PCM if a good device won't connect.
If you can locate a spare IDM and do a quick swap you can rule that out.
A PCM swap will need to be one similar to yours.
post #10 of 11 Old 08-28-2019, 03:22 PM
Quoted: 299 Post(s)
