VSS - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-23-2019, 05:58 PM Thread Starter
Quoted: 4 Post(s)
VSS
Driving today truck went into limp mode. No forward or reverse. Speedo has bounced since I've owned the truck. Replaced the VSS and no change. Code from today was P0500 for the VSS. Pulled the diff cover to check the tonering. Found this. Is this enough to cause the problem? How much and how difficult is it to replace the tonering if this is causing my problem? Thanks in advance.
Sent from my SM-G965U using Tapatalk
Broke-7.3 is offline
post #2 of 3 Old 06-24-2019, 03:39 PM Thread Starter
Quoted: 4 Post(s)
Anyone? I have all the gear oil and friction modifier to fill it back up but don't want to waste it if this is the problem.
post #3 of 3 Old 06-25-2019, 04:09 AM
I have no idea if those damaged "teeth" on the tonering would cause VSS issues you are having????
I would also try to figure out what caused the damage before replacing - or just putting it back together.
I have no idea of how to replace it either.
Sorry - I'm no help - Broke.
Audiowriter is offline
