In the meantime... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-22-2019, 03:21 AM Thread Starter
In the meantime...
I have 2 each - 97 F350 1 ton dually's 2WD / Auto trans. (pic's below)
While waiting on parts to do a compression check on my main hauling conversion truck...
The other back up truck incurred a most incredibly odd malfunction.
Lets play a little game of "guess that part".
Below is a picture of the part that caused me sooo much irritation - can you guess what it is?
Name:	Hansel and Grettle Small.jpg
ID:	720183   Click image for larger version
Name:	What part is it.jpg
Audiowriter is offline
post #2 of 8 Old 06-22-2019, 04:15 AM
White_Buffalo7.3's Avatar
Quoted: 177 Post(s)
Garage
An advanced clothe hanger
White_Buffalo7.3 is offline
post #3 of 8 Old 06-22-2019, 05:33 AM Thread Starter
It does look like one...
But these pieces are only about an inch or two long...
post #4 of 8 Old 06-22-2019, 06:20 AM Thread Starter
HINT =
"BRAKES..."
post #5 of 8 Old 06-22-2019, 08:20 PM
Quoted: 297 Post(s)
Dust shield? Maybe a support that came loose and rattled?
White95f250 is offline
post #6 of 8 Old 06-23-2019, 03:17 AM Thread Starter
Well - below is a pic of what it used to be.
My brakes suddenly started to "jerk" - like it was an ABS problem - but no ABS light.
Months earlier I had replaced both front calipers because they were starting to stick and get warm.
I though maybe I had some air in the lines - so I bled, and bled, and bled the brake system - even the ABS bleeder - but the jerking persisted.
I took apart the right rear brake drum - and found the culprit.
The self adjuster cable had broke - and the upper end of the cable still attached to the brake post was getting in between the show and the drum....
BUT - the other end of the self adjuster apparatus was also "occasionally" getting in between the shoe and the drum -
causing the "jerky" brakes.
Never heard of this one before... has anyone else?
ID:	720211   Click image for larger version
Name:	Auto Brake Adjuster.jpg
post #7 of 8 Old 06-23-2019, 09:23 AM
Quoted: 37 Post(s)
I actually had the same exact problem as you, on my left rear drum, the brakes wouldn't pulsates or anything but I could hear a grinding noise, luckily the hardware kit is only like $10.
1994fordf350 is offline
post #8 of 8 Old 06-24-2019, 03:35 AM Thread Starter
1994ford350
Wow. Never this is the first I've head of anyone else having this self adjuster problem.
I replaced everything too - including the slave cylinder.
For my experience - every time the spring and apparatus parts would "lodge" in between the shoe and drum - the truck would jerk hard - like the abs was freaking out.
But - I could let off the brakes - then the darn thing would get free somehow - and the brakes would work fine for several braking instances.
It would come and go at random times.
The spring was in there too - it was a little mangled - but it stayed in the bottom of the drum between the shoes........???
