PCM PART - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-21-2019, 07:03 PM Thread Starter
PCM PART
Iím looking for a PCM for a 1997 F250 7.3L Heavy Duty Diesel 4x4.
lobodad is offline
post #2 of 2 Old 03-22-2019, 04:05 PM
Patrick Feeley's Avatar
Quoted: 72 Post(s)
Automatic or 5-speed? California or 49-State (Federal)? California trucks will have a shunt and Glowplug Monitoring Circuit wiring on the Glowplug Relay, a pulse damper on top of the Fuel Pump's banjo fitting at the rear of the pump. Cheers!
Patrick Feeley is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
what's this part pass1over General 6.0L Discussion 8 08-30-2018 05:49 AM
Fuel Heater part looks different Elder Elemental Evil 99-03 7.3L Powerstroke Problems 4 09-30-2017 12:12 PM
99-03 7.3 same wiring harness several part numbers? cmb7684 99-03 7.3L Powerstroke Problems 3 09-06-2017 07:18 PM
Front Suspension Part Numbers Inside Cajundude 6.4 Drivetrain Problems 8 02-05-2017 05:52 AM
