Is their such a truck? - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 23 Old 11-04-2017, 05:04 AM Thread Starter
Quoted: 2 Post(s)
Exclamation Is their such a truck?
has ford ever made this truck:
1997 ford f350 xlt hd v8 powerstroke turbo diesel super crew cab long bed off road dually?
TheCrimsonKing is offline
post #2 of 23 Old 11-04-2017, 06:52 AM
By off road do you mean 4x4? It is my understanding (and Lord knows I could be wrong) but Ford did not make a factory 4x4 OBS dually. If you find one, someone else has converted the dually to 4x4. I was told this by someone way more knowledgeable about these trucks than I am.
Welder guy is offline
post #3 of 23 Old 11-04-2017, 10:09 AM
1Dieselman's Avatar
Quoted: 222 Post(s)
Feedback Score: 4 reviews
No, Ford did not build a obs 4x4 dually. There where a couple of company's that did conversions, Higley and Centurion with Centurion being more popular. My son and I built one for him a year or so ago using a 95 F-350 2x4 crew cab dually and a 97 F-350 4x4 frame. He is often offered big bucks for it.
Welder guy likes this.
Jack
_______________________________________________
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
323000 miles
1Dieselman is offline
The Following User Says Thank You to 1Dieselman For This Useful Post:
TheCrimsonKing (11-05-2017)
post #4 of 23 Old 11-04-2017, 10:35 PM
Quoted: 326 Post(s)
There's a few around here that converted theirs and one buddy put a 12v in it.
They sure are sweet. 4dr 4x4 long bed dually 5 speed.....mmmmmm
White95f250 is offline
post #5 of 23 Old 11-05-2017, 05:55 AM Thread Starter
Quoted: 2 Post(s)
@1Dieselman
right on thanks, how would i go about doing the conversion with one of those companies or just go about doing the conversion period? and could you describe the process you did for how you built yours please?
post #6 of 23 Old 11-05-2017, 06:00 AM Thread Starter
Quoted: 2 Post(s)
@White95f250
they did the conversion and put a v12 engine in the truck??? didnt know ford made a v12 engine, i know of a v10 triton engine though, if ford did make a v12 that would be awesome to put in it, thought about making it an 8 liter v8 and straight piping it, is it stret legal to have a 12 liter v12? or something like that?
post #7 of 23 Old 11-05-2017, 06:12 AM
1Dieselman's Avatar
Quoted: 222 Post(s)
Neither one of those companies are in business. We used the body, engine, wiring, rear axle and rear suspension from the 95 2x4 dually and the frame, front axle, front suspension, drive shafts, and transfer case from the 97 4x4 that came with a 460. We found a E4od 4x4 trans from behind a powerstroke and a set of centurion front wheel spacers to finish it off.
Jack
323000 miles
TheCrimsonKing (11-06-2017)
post #8 of 23 Old 11-05-2017, 06:14 AM
1Dieselman's Avatar
Quoted: 222 Post(s)
Originally Posted by TheCrimsonKing View Post
@White95f250
He is referring to a 12 valve Cummins engine
Jack
323000 miles
post #9 of 23 Old 11-05-2017, 06:52 AM
Quoted: 326 Post(s)
Yes 12 valve Cummins.
Every person i've talked to went out and got a donor truck or two and swapped everything over.
post #10 of 23 Old 11-06-2017, 07:15 AM
Quoted: 26 Post(s)
Garage
I built mine. I started with a 4X4 Crew Cab F350 and converted it to dually. I put the rear from a 2X4 in and found a dually bed. Then I converted my D60 up front to dually by swapping out the hubs. The hardest part of the whole project was finding a decent dually bed.
Name:	F350 White.jpg
1Dieselman likes this.
2005 F550 4X4 Crew Cab Lariat Flatbed 270K miles ARP Studs and basic maint updates otherwise stock. For Now.
*Sold*1997 Crew Cab Long Bed 4X4 (DRW Conversion)
ChallengerRV is offline
The Following User Says Thank You to ChallengerRV For This Useful Post:
elephantrider (11-06-2017)
