Frame Damage - Page 2 - Ford Powerstroke Diesel Forum
 5Likes
post #11 of 20 Old 06-23-2017, 06:07 AM Thread Starter
lopealle's Avatar
Quoted: 2 Post(s)
Originally Posted by masakimm View Post
I wouldn't call the receiver good It's side plates are pretty mangled. I can see why they would want a whole frame even if you get that straight it will not be as strong.
Isn't there a way that a welder can make it stronger?
Originally Posted by White95f250 View Post
Right by the rear spring mount. That hurts. Best thing to do is take the hitch mount off, thats holding a lot of stress.
The take it to a GOOD alignment shop and have them check the alignment in relation to the front wheels.
As stated it will not be as strong and the rear spring mounts could be binding enough to cause issues further down the road. I wouldn't trust it to tow anything that's a reasonable load.
I have taken it to 2 different alignment shops and it passed with flying colors even after driving it 3k miles from Washington to Alabama.
Originally Posted by zsargent View Post
that is no bueno.....
Definitely no bueno.
Originally Posted by Heavy_GD View Post
after I argue the value of replacing that truck... I'd let em total it, buy it back and pull the bed for a new rear half with some extra gussets welded in.
I skipped the whole totaling it out. I just let the insurance company cash me out.
lopealle is offline
post #12 of 20 Old 06-23-2017, 06:58 AM
Quoted: 299 Post(s)
Cut the hitch out of there and see where the frame settles. Be careful because it is under pressure.
After that then you can start straightening the frame if you want. But it will need strengthened
White95f250 is offline
post #13 of 20 Old 06-23-2017, 07:06 AM
Heavy_GD's Avatar
Quoted: 3109 Post(s)
Garage
Feedback Score: 4 reviews
He cashed out... we will have a new member posting about their new project truck soon.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #14 of 20 Old 06-23-2017, 07:39 AM Thread Starter
lopealle's Avatar
Quoted: 2 Post(s)
I don't know how to do that stuff nor do I have the equipment. Is it something a weld shop can do.
Project my a$$. I just need to get it fixed. It's my work truck. Well maybe there will be a "New Project" thread
Heavy_GD likes this.
lopealle is offline
post #15 of 20 Old 06-23-2017, 08:26 AM
Quoted: 133 Post(s)
Using a donor frame, a certified welder could replace the mangled sections and reinforce the weld,points with additional reinforcement plates that would make this better then new.
JustinOOO9 likes this.
Rossterman is offline
post #16 of 20 Old 06-27-2017, 04:55 AM Thread Starter
lopealle's Avatar
Quoted: 2 Post(s)
I guess it's time to start lurking junkyards local to me. I will post an update to you guys once I get things going. Thanks for all the info
lopealle is offline
post #17 of 20 Old 06-27-2017, 05:06 AM
Heavy_GD's Avatar
Garage
I still think you should talk to a fab shop about building a frame.
GD
Heavy_GD is offline
The Following 2 Users Say Thank You to Heavy_GD For This Useful Post:
JustinOOO9 (06-27-2017)
post #18 of 20 Old 06-27-2017, 05:23 AM
ZMANN's Avatar
Quoted: 3899 Post(s)
steel flatbed with integrated hitch
6.0 flush pdf
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
Heavy_GD (06-27-2017)
post #19 of 20 Old 06-27-2017, 08:57 AM
JustinOOO9's Avatar
Quoted: 1539 Post(s)
Garage
Feedback Score: 3 reviews
If you find a good fab/weld shop they can cut and weld that fairly easy... Frame damage is always big with insurance but for a person with welding and metal experience its no problem at all. I would think its gonna be a little pricey if you have someone do it. but cut a price off a wrecked truck and bring it to a welder and it SHOULD be no problem unless the frame is rusted out in sections close.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
Justin
JustinOOO9 is offline
post #20 of 20 Old 06-27-2017, 11:39 AM
RidinHigh's Avatar
Quoted: 12 Post(s)
My buddy recently went through a similar situation but his frame was destroyed their from a rust and sled pulling situation, he settled on having a good used rear half of frame spliced in behind the box and fish plated. iirc I think he was into it for like 700 bucks when all was said and done.
RidinHigh is offline
