97 7.3 torque converter/shift issues - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-14-2019, 06:13 PM Thread Starter
KyleCook's Avatar
Quoted: 3 Post(s)
Garage
Hey, my truck is driving like the torque converter is locked up. If I let off the accelerator pedal it decels quick like a standard. It is shifting super hard. Does it sound like wiring?
KyleCook is offline
post #2 of 10 Old 11-14-2019, 06:21 PM
Patrick Feeley's Avatar
Quoted: 81 Post(s)
Is the OD light on the shifter flashing? If so, you'll need to retrieve the diagnostic trouble codes that have been set. Cheers!
Patrick Feeley is offline
post #3 of 10 Old 11-15-2019, 07:25 AM
Quoted: 307 Post(s)
Get a scanner hooked up and read MAP, BPS, and EBP pressure readings. All should be reading nearly the same.
BPS sensor can cause harsh shifts and bad loping during decel etc..
Also make sure all of your tail lights are working and all fuses are good.
White95f250 is offline
post #4 of 10 Old 11-15-2019, 09:23 AM Thread Starter
KyleCook's Avatar
Quoted: 3 Post(s)
Garage
Hey, I hooked up forscan and am getting no codes. I'm assuming I am supposed to check all those while the truck is running?
KyleCook is offline
post #5 of 10 Old 11-15-2019, 09:24 AM Thread Starter
KyleCook's Avatar
Quoted: 3 Post(s)
Garage
I recently cleaned my ebp tube and sensor but was having issues before. It wasn't very dirty. I have noticed that the ebpv comes on quite strong when cold.
KyleCook is offline
post #6 of 10 Old 11-15-2019, 09:29 AM Thread Starter
KyleCook's Avatar
Quoted: 3 Post(s)
Garage
Also, the o/d light is not flashing and if I press it it will light up.
KyleCook is offline
post #7 of 10 Old 11-15-2019, 10:36 AM Thread Starter
KyleCook's Avatar
Quoted: 3 Post(s)
Garage
Those are my codes I got. The code reader doesn't seem to want to pull them. Forscan won't pull any codes.
KyleCook is offline
post #8 of 10 Old 11-15-2019, 05:35 PM
Quoted: 81 Post(s)
Check the codes with the key in RUN. Is there oil in the ICP connection? Cheers!
post #9 of 10 Old 11-16-2019, 10:51 AM Thread Starter
KyleCook's Avatar
Quoted: 3 Post(s)
Garage
I've tried to pull the codes with the engine running and it shuts it off. I only ever try and pull the codes with the key on.
KyleCook is offline
post #10 of 10 Old 11-16-2019, 10:52 AM Thread Starter
KyleCook's Avatar
Quoted: 3 Post(s)
Garage
I replaced the ICP sensor with a cheap Amazon one and I have it unplugged right now. The old one leaked oil through and into the wiring. I put a new wiring harness on it. I have it unplugged as I was having a starting issue and was seeing if that was it.
KyleCook is offline
