97 complete tranny failure. - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By 1Dieselman
post #1 of 6 Old 09-03-2019, 04:53 PM Thread Starter
Friend just called me, his auto tranny just dropped most of his tranny fluid pulling an aprox 8000 lb fifth wheel up a fairly good grade, Hwy 4 in Ca for the locals. Temp was at 260 f. Who builds the best tranny in the Northern Cali area ? Thanks in advance.
Hans van Loo is offline
post #2 of 6 Old 09-03-2019, 07:47 PM
1Dieselman's Avatar
Quoted: 222 Post(s)
Feedback Score: 4 reviews
I can't help with who builds what in Cali but I can tell you with those temperatures he most likely blew the front seal out of it. I've seen it happen many times. Most of the time you can replace the seal and be good to go. He obviously also needs a much bigger trans cooler.
SparkyF250 likes this.
Jack
_______________________________________________
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
323000 miles
1Dieselman is offline
post #3 of 6 Old 09-03-2019, 09:20 PM
Quoted: 326 Post(s)
White95f250 is offline
post #4 of 6 Old 09-04-2019, 08:41 AM
00t444e's Avatar
Quoted: 608 Post(s)
John Wood automotive
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #5 of 6 Old 09-05-2019, 02:37 PM
Corey@CNCFAB's Avatar
Quoted: 1455 Post(s)
John Wood for sure. Not sure if he is in N. Cali, but he would be the closest. I just shipped a trans to a customer in N Cali and it was less money with shipping than John was, but, he is a very good builder and will take care of you.
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
post #6 of 6 Old 09-05-2019, 05:17 PM
Patrick Feeley's Avatar
Quoted: 85 Post(s)
John is in Southern California (Holtville which is about 10 miles east of El Centro near the Cali/Mexico border). Cheers!
Patrick Feeley is offline
