95 Power Stroke with no glow plugs? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-06-2005, 12:59 PM Thread Starter
My 95 power stroke has dificulty starting.
I check the glow plug relay.
Then pulled off valve cover to get at the glow plugs, to find out they do not have glow plugs. They are glow plug modules or something like that (not sure what to call them). Not sure how to test or whether they are the problem.
Went to Schucks/Napa auto and they say the 95 power stroke has glow plugs. Does anyone know anything about these glow plug modules or how to test them?
95ps_wo is offline
post #2 of 2 Old 11-06-2005, 06:38 PM
Worm Drowner's Avatar
Garage
Are you sure that you're not confusing the injectors with the glow plugs? The glow plugs themselves are buried down amongst the rocker arms. If the glow plugs haven't been changed before, they are likely due. You can get them at Autozone for around $10 ea. Be careful that you don't knock the injector wires loose or the truck won't run worth a darn. I found that out the hard way after putting it all back together.
Worm Drowner is offline
