7.3 turbo question - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-10-2019, 05:07 PM Thread Starter
7.3 turbo question
I took the air inlet tube off and found my compressor wheel to have chips in it. i have been looking online and found alot of people talking about having the turbo balanced after changing compressor wheel. i understand why and was wondering would a kit from kc turbo called the balanced rotating assembly be all i need.
i also have already disassembled my turbo to inspect it and found oil leaking from the seals on the ends of the turbo shaft. i know i will have to rebuild it either way.
just wondering if anybody has used these kits? Is it all i need to rebuild the turbo? is this the way i should go?
The truck is basically stock factory injectors. only performance mods 6 position chip and 3in downpipe. It is a 5sp truck. For the next couple years it will stay mostly stock.
dieselvic is offline
post #2 of 5 Old 11-11-2019, 03:30 AM
Quoted: 304 Post(s)
White95f250 is offline
post #3 of 5 Old 11-11-2019, 07:35 PM
Turbostang500's Avatar
Quoted: 6 Post(s)
I don’t have any experience with that kit. I have however installed a ww2 from Dieselsite in my 2000 7.3. As far as I am aware, with threaded wheels, the wheel is neutral balanced and the turbine shaft should be as well. So, in theory, the two can be threaded together and still be within factory tolerance with regard to balance. Maybe I was just lucky, but we also do this with our triple turbo pulling tractor without issue.
We do not use impacts on it though!!!!!
The turbo is removed and disassembled so a wrench or socket can be put on the turbine nut and torque the compressor wheel.
I also added a 360* thrust bearing to my 7.3 turbo for added measure.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #4 of 5 Old 11-11-2019, 11:42 PM
Googs's Avatar
Quoted: 15 Post(s)
I would highly recommend balancing the rotating cartridge.
I had a WW2 fitted some years ago and didn't do the balance on the CHRA, this was ok for thousands of miles.
Then on the way home after our travels with the travel trailer the shaft broke and let us down, and not to mention the breakdown fee.
So for just a little extra cost you can have trouble free motoring and peice of mind.
Sent from my SM-G965F using Tapatalk
2003 F250 4X4 CC 7.3, 4R100HD, GTP 38R, RR IC boots, Plenum inserts,
4' Turbo back exhaust, Banks Power Elbow, LPG (Gas over Diesel), DP Tuner F6, RR 6637 intake Custom , RiffRaff Frx, Hpx, filter, Custom made transmission cooler with twin thermo fans, water to oil cooler, ScanGuage 2, Auto Meter, trans, EGT, Fuel pressure, Water to oil temp, Boost, Longrange fuel tank, 15000 Lbs winch, ARB winch bar, ARB lockers Fr & Rr, lightforce spot lights, HID's.
Googs is offline
post #5 of 5 Old 11-12-2019, 07:14 PM
Corey@CNCFAB's Avatar
Quoted: 1428 Post(s)
Feedback Score: 4 reviews
The balanced rotating assembly from KC is a better way to go, but isn't necessary. Each part (turbine wheel and compressor wheel) are component balanced. Meaning each they are balanced separately. High volume turbo manufacturers do not balance them as an assembly.
That being said, the KC assembly is much better not because it's assembly balanced, but because of the upgraded turbine wheel. It's a big improvement with their billet compressor wheel.
We keep their kits on the shelf.
https://cncfab.us/i-30498942-kc-turb...it-300317.html
www.cncfab.us
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
