Idle issue - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-28-2019, 06:36 PM Thread Starter
Jakethepowerballer's Avatar
Idle issue
Hey guys. New to the forum and couldn’t find a thread with this issue.
My truck is a 97’ 7.3l with 170k miles..
So when I cold start or the truck is warm, When I’m idling in park, or in drive at a stop light the RPMs are a tad jumpy. They go up and down by about 50-100 rpms. No real pattern to it. The a/c is off so I know the motor isn’t under any load. Can’t seem to figure out the issue. Just changed the oil, Any help on this would be great.
Thanks guys
Jakethepowerballer is offline
post #2 of 3 Old 09-28-2019, 08:16 PM
Quoted: 300 Post(s)
I have a similar issue but it's most likely the IPR.
A good scanner can show you IPR % and ICP pressure.
Double check the wires and nut on the back of the IPR
White95f250 is offline
post #3 of 3 Old 09-29-2019, 06:36 AM
Patrick Feeley's Avatar
Quoted: 79 Post(s)
And make sure the "tin nut" holding the IPR solenoid on is snug too. Cheers!
Patrick Feeley is offline
